100% wifi battery usage in connected standby
Discussion in 'Windows 10 on Surface 3' started by RichStant, Dec 14, 2015.
  1. RichStant
    RichStant New Member
    Dec 14, 2015
    4
    0
    Surface 3 (Atom)
    Hi,
    Just got a Surface 3, windows 10. Have all the latest firmware & windows updates. Everything works fine, however when I put the device to sleep, the battery is still used quite heavily. Using powercfg /sleepstudy, I see that the Avastar wireless is responsible & is in use 100% of the time during sleep. I don't see lots of other threads with this problem - am I alone? Or is this a buggy wifi driver issue?
    Thanks!
  2. Zippy0n
    Zippy0n Member
    May 21, 2015
    85
    11
    8
    Probably better suited for the Surface pro 3 forum - admin?
  3. RichStant
    Dec 14, 2015
    4
    0
    Surface 3 (Atom)
    Please don't move it, it was a typo - should just be surface 3, not pro! Have edited the original post to correct the error...
  4. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Thread moved.
    Something is trying to run, perform some activity, and hasn't had a chance to complete it. My suggestion for at least a little while would be to turn it off instead of putting it into sleep. You could also tell it to turn off WiFi while sleeping. Bottom line, something is trying its best to complete a task.
  5. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Moved back ;) ;)
  6. RichStant
    Dec 14, 2015
    4
    0
    Surface 3 (Atom)
    It's been another day, I've tried either turn off, hibernate or connected standby, and I'm still getting huge wifi use in connected standby. Drilling down, it's always NDIS that's using the battery. Any idea what this indicates is the culprit?
  7. GreyFox7
    Jul 27, 2014
    6,899
    1,385
    113
    Have you tried uninstalling the wireless driver in Device Manager? It will automatically reinstall. sometimes that helps.
  8. RichStant
    Dec 14, 2015
    4
    0
    Surface 3 (Atom)
    Tried that thanks, no difference. Although I did find that disconnecting from the wireless solves the problem!
  9. kristalsoldier
    kristalsoldier Well-Known Member
    Feb 24, 2013
    2,379
    371
    83
    Yeah that Marvel Wifi set up that MS uses is not very good.
