Ahhhh...wifi issue is maddening
Aegeas
That is the most recent version of the Marvell driver. When you install the Intel drivers you are updating the core chipset drivers. That has been the key to my stability. Manually installing the latest video drivers has been the key to my video performance.
Use this link:
http://www.intel.com/p/en_US/support/detect
There is another discussion in this forum on where to get and how to install the latest video driver.
My video driver version is : 10.18.10.3907
You have to manually install this driver version as it was not approved for use on the Surface yet, but it was designed for this chipset, improves battery life, and really helps with video performance.
Best of luck.
Use this link:
Best of luck.
Which chipset drivers are you using?
ctitanic
Just venting here..... This Wi-Fi not being connected on startup or resume is driving me crazy.
How is it possible this is not fixed yet?
Of all the compromises that you have to put up with, this is the worse.
This turns a nearly perfect tablet/laptop experience into a reminder that you have a "SP3", so don't forget you "are not on WiFi yet"
Done venting.... fix it !!
Try this workaround
http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfnetwork/surface-pro-3-limited-wifi-problem/bd17691d-f00d-491c-a65e-fcd77a304b3a?page=41&msgId=47e4fbee-b56a-4248-98b1-c1ea1318b994
