Anyone have an Ativ Pro
Discussion in 'Samsung Windows Tablets' started by Afy, Mar 27, 2013.
  1. Afy
    Afy Member
    Nov 9, 2012
    403
    18
    18
    If so what has your experience been thus far?
  2. souldier
    souldier Active Member
    Feb 5, 2013
    243
    27
    28
    I don't have one but I've used it at the Microsoft store. I opted for the Surface Pro because with the Ativ, you'll usually need to bring it around with the keyboard dock, which adds a lot of weight to the device. Further, it doesn't have a built in kick stand, so you can't prop it up whenever you like unless you put it in the dock. Another problem is the dock doesn't have secure connection and often disconnects with the slightest movement, which would be really annoying. The ativ is also 11.6 inches which isn't the most pleasing size for a tablet, where as I find the 10.6 inch surface is a lot more pleasing to use especially as a tablet. The build and quality of the ativ I also find quite cheap and the usb ports and such have plastic covers which I find annoying.
    With the surface pro, I don't need to buy any folio case or anything since it has a kick stand and a cover for the screen, while it serves as a keyboard at the same time, making it considerably lighter than the ativ when docked.
    IF you're looking for something like that, I think the best viable options are the Surface Pro or the Acer W700. If I wanted something like the Ativ, I'd probably just opt for an ultra book
  3. dvdcatalyst
    dvdcatalyst Guest
    I don't have one either, but I do have a Surface Pro and an Acer W700
    I use mine with either a (usb) trackball for work-stuff, or the xbox-controller (with usb dongle) for games.
    With only one USB port on each one, I prefer the Surface Pro because of the keyboard connection.
    The Acer uses bluetooth for it, and it lags and disconnects all the time. With the Surface, I have the USB port free for what I need, and still have the ability of using the keyboard at the same time.
    The only thing I hate about the Pro is the storage. I upgraded the Acer with a 240GB Mushkin, but don't dare to do the same with the Surface.
  4. Tom T
    Tom T New Member
    Jun 25, 2012
    146
    14
    0
    RT
    Yeah, as much as I wanted a Surface Pro it was the storage that ultimately changed my mind. I ended up buying a Lenovo Thinkpad Twist ultrabook that has a hybrid storage system with a 500gig hd. Plus it was considerably less expensive , $670 on sale, and I felt the Pro might make my RT somewhat of a paperweight (although probably not considering the battery life of these Core I5 devices).
  5. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    It's obvious that Microsoft made a couple wise design decisions with the touch cover and kick stand.
ativ pro
