"Balanced" or "Power Saver"?
Discussion in 'Microsoft Surface Pro 2' started by Sir Face, Mar 21, 2014.
  1. Sir Face
    Sir Face New Member
    Jan 31, 2014
    96
    5
    0
    Do you find that the "Balanced" or the "Power Saver" setting works best for you in terms of getting the best overall battery life from Your Surface Pro 2 and why?
  2. hksrb25s14
    hksrb25s14 New Member
    Oct 29, 2013
    76
    31
    0
    I don't know but when I have powesaver
    My Video streaming gets choppy and when in balance mode it's plays okay when shutter here or there.
  3. mennogreg
    mennogreg Active Member
    Dec 24, 2013
    188
    32
    28
    This may just be a quirk in my machine or setup (or maybe even a bug), but I get better battery life from Balanced than I do Power Saver; roughly an hour and a half more. Its weird because my power saver profile settings are all set to maximize power savings, and the CPU is throttled to 80%.
  4. GoodBytes
    GoodBytes Well-Known Member
    Jan 29, 2014
    1,071
    170
    63
    The percentage that you set the CPU is rounded to a power state it support.
    Set it the min and max to 0%. Power Saving should give you better battery life when doing office level work.
balanced or power saver micosoft 2011
balanced vs power saver
microsoft surface battery saver
surface pro 2 balanced vs power saver
surface pro 3 power profiles only balanced
surface pro 3 power saver
surface pro 3 power saving
surface pro balanced vs power saver
surface pro3 power saver
surface proenergy saver
