Battery deterioration during gaming and charging
malberttoo
Hi all
Is using charging battery during gaming. Is it deteriorating for battery ?
Use the machine as you see fit, and make sure that once a month you let it discharge to below 10%.
Leaving it plugged in during gaming will not hurt the battery.
L
lukas108
Great to hear that. Thanks.
I have another question - does APU's temperature affects a battery ? As far as i know high temperature generally is not good for batteries. So, how is it solved in Surface Pro 3? Proper placement?
