Battery Life
Discussion in 'Microsoft Surface General Discussion' started by NickP, Dec 29, 2012.
  1. NickP
    NickP New Member
    Dec 29, 2012
    6
    0
    0
    England, between London & Oxford
    SPro2
    I have the 64 gig RT purchased in the USA.The problem is that the battery lasts less than 24 hours even if it's closed and not being used (i.e. on stand-by). If I'm using it I get barely an hour. I do have the screen fairly bright. Was told by salesman that it should last 6-8 hours in use, 4 hours or so watching video and up to 10 days or so when on stand-by.
    Don't think there is any programme running full time as I shut them down.
    I would welcome any thoughts.
    Nick
  2. bosamar
    bosamar Well-Known Member
    Nov 10, 2012
    1,453
    78
    48
    RT
    If your RT battery only lasts one hour of use on a full charge then you've got a big problem.... contact tech support....
  3. Sin
    Sin New Member
    Nov 14, 2012
    470
    32
    0
    Connecticut, USA
    RT
    Do you have any process pegging the CPU? Take a look at the Task Manager and see if anything is running constantly that might be chewing through your battery. Otherwise your battery most likely has a problem and you need to contact tech support.
  4. R0bR
    R0bR Member
    Nov 20, 2012
    332
    19
    18
    On full charge I watched 3 movies and still had juice, I can get a full day of regular use out of it.
  5. Mr.Dan
    Mr.Dan New Member
    Nov 9, 2012
    27
    0
    0
    Deffinitely Theres something running in background, try refreshing the device, or uninstall some apps with news feed.. It may update way too often, had issues like this with appy geek (possibly)
  6. Rick Sutliffe
    Rick Sutliffe Member
    Oct 30, 2012
    130
    6
    18
    Buffalo, NY
    You may have already tried this, but try simply turning the Surface off. Press and hold the button at the top right, which will turn the Surface off rather than closing the cover which causes it to sleep. This is basically a reboot. Rebooting has cured a bunch of minor issues I've accumulated with my Surface.
  7. gpstrucker
    gpstrucker New Member
    Dec 22, 2012
    92
    13
    0
    On the road
    RT
    I would also suggest turning on airplane mode when mot using WiFi so the radio isn't draining the battery, but honestly it sounds like maybe you got one with a defective battery. I would do as suggested and contact tech support.
  8. surfacetablethelp
    surfacetablethelp New Member
    Jan 4, 2013
    27
    0
    0
    Go to close the background running apps
  9. NickP
    NickP New Member
    Dec 29, 2012
    6
    0
    0
    SPro2
    Thanks to all for the feedback. I think that I had music playing in the background. I tried the re-boot, re-charged and with limited use I'm still at 60% after 3 days. It is very easy to leave something running so be careful all.
    Nick
  10. uh60james
    uh60james New Member
    Jan 2, 2013
    14
    0
    0
    Southeastern US
    It's still Windows, albeit a "light" version, so the easiest troubleshooting step is always a reboot! Glad it worked for you.
stand by battery life on the surface
surface battery life forums
surface forums battery life
surface pro battery life forums
