Best Prepaid Mobile Broadband Plan/Device
Discussion in 'Microsoft Surface Pro 3' started by btcoon7, Nov 23, 2014.
  1. btcoon7
    btcoon7 New Member
    Nov 23, 2014
    6
    0
    Guys what you use with your Surface Pro 3s?
    I was using VM broanband2go 4g unlimited plan, but windows 8.1 doesn't work
    with the VM u600 usb stick. So shopping for new plan/device.
    What you use?
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Welcome to the forum
    Wal-Mart has a prepaid, (never expires) portable hotspot that works with anything.
  3. kozak79
    kozak79 Active Member
    Nov 15, 2013
    296
    61
    28
    Not sure what phone you have, but you can set up a hotspot through your phone, which most carriers charge $20 a month for and you share your data plan.
    Price Breakdown from http://techland.time.com/2014/02/04/hotspot-share-your-phones-mobile-data-with-other-devices/
  4. guymalloc
    guymalloc Member
    Apr 1, 2014
    130
    23
    18
    Nebraska
    I use a Virgin Mobile Sierra Wireless Pro 3g/4g wireless hotspot. I'm grandfathered in on a $35 per month 2gb 3g, and unlimited 4g (up to 10gb then throttled) plan. Works perfectly either wireless or plugged in to a usb port. Battery lasts about 4 hours, same as my Surface Pro 1 lasts when busy. Download speed is about 9.5 MGBs, upload about 3 MGBs. Can connect 5 devices wirelessly.
  5. btcoon7
    btcoon7 New Member
    Nov 23, 2014
    6
    0
    Guys hi, thank you for your replies.
    @ guymalloc - i have exactly same plan, but i have u600 usb stick.
    Trying to make it work...
  6. guymalloc
    guymalloc Member
    Apr 1, 2014
    130
    23
    18
    Nebraska
    I had a VM usb stick before I got the Sierra Wireless Pro. It never connected better than 3g, and was slow as dialup. Needed another option, as I won't pay $60 a month for cable internet, and needed something portable. I've been very pleased with my setup...
  7. daniielrp
    daniielrp Active Member
    Oct 26, 2013
    693
    133
    43
    Preston, UK
    I have a Three Mi-Fi, but not pre-paid, I pay £8 p/m for 5GB data.
  8. btcoon7
    btcoon7 New Member
    Nov 23, 2014
    6
    0
    guymalloc are using that device -> https://dl.dropboxusercontent.com/u/92344414/5124855.jpg
    Virgin Mobile Over Drive Pro? And it IS working with windows 8.1 / Surface Pro 3, right?
  9. guymalloc
    guymalloc Member
    Apr 1, 2014
    130
    23
    18
    Nebraska
    Yes, I'm using The Virgin Mobile Overdrive Pro, but with Windows 8.1.1 on my Surface Pro 1. I haven't seen the need to upgrade to a SP3 yet, Maybe when the SP4's come out and the price drops. It has been working flawlessly with the SP1.
best prepaid surface
best mobile plan for surface devices
how do i get prepaid data on my microsoft surface
is virgin mobile hotspot plan an additional 2 gb of data on monday
microsoft surface pro unlimited data
mobile internet devices unlimited plans
ms surface mobile internet stick
prepaid data plans for windows surface
prepaid internet for a surface microsoft
prepaid moblie broadband surface
