Car charger for the Pro
Discussion in 'Microsoft Surface Pro' started by drolem, Aug 10, 2013.
  1. drolem
    drolem Active Member
    Aug 9, 2013
    293
    36
    28
    98052
    Is there a cigarette lighter adapter for the Pro?
    I searched, and there is apparently quite a few for the RT (12V/2A) but I'm not certain they would work. Strictly speaking, even if it can't charge the battery but can power the Pro, that would be enough.
    Did anyone try an RT car adapter with the Pro?
  2. ScottyS
    ScottyS Active Member
    Apr 14, 2013
    725
    125
    43
    New York
    MikeGyver.com has car adapter and external battery at: Microsoft Surface External Battery & Car Adapter Charger .
    A problem with this has been discussed previously on this forum (http://www.surfaceforums.net/forum/...-adapter-not-pro.html?highlight=MikeGyver.com) but I think the problem has been fixed.
    Others have used 12V DC-to-120V AC power inverters to run the regular AC charger in their car.
    Since getting my Surface Pro I have turned it into my only PC, plugging it into a Dell UltraSharp U2713H 27" Monitor running at 2560X1440 resolution via the miniDisplayport and a USB 3 9 port hub (with 3.25TBs of various HDs and a DVD burner) and use a wireless Logitech keyboard and MS mouse. So having a 2nd charger for my office or travel and as a back-up is critical. I looked into buying a third party (read:cheap) charger but when I read the comments posted about sparks and meltdowns, I ended up buying a 2nd MS charger for $80.
best 3rd party surface pro 2 car charger
car charger adapter for surface pro 3
in car charges for surface pro 3
microsoft surface pro 2 charger sparks
surface pro 3 car cigarette charger nz forum
surface pro 3 cigarette
surface pro 3 cigarette lighter charger
surface pro car charger
surface pro car charger problems
surface pro case
