Charging issues
Discussion in 'Microsoft Surface Pro 2' started by rege0039, Dec 12, 2013.
  1. rege0039
    rege0039 Member
    Nov 26, 2013
    130
    5
    18
    Hi,
    I'm new here and think this might be an old problem but m Surface Pro 2 won't charge.
    Left it charging all night and it stayed at 13%. Turned it off and on an it now says 'plugged in, not charging'.
    Had a look around and it seems like a known problem. Any known fixes other than a 30 mile drive to replace or refund it ?
    Thanks for any/all help.
  2. Jasmine
    Jasmine Member
    Nov 19, 2013
    46
    5
    8
    Surface 3 (Atom)
    Nope, your best bet is an exchange, assuming that's what you want.
    I have the same issue. Sometimes it charges, sometimes it doesn't. Either way, I'm getting a terrible battery life -- averaging 3 hours or so.
  3. rege0039
    rege0039 Member
    Nov 26, 2013
    130
    5
    18
    It does seem to be charging and giving my normal battery life (6-8 hours) but the percentage displayed on the desktop doesn't seem to change.
    It knows it's charging and then stops charging, presumably when it is full.
  4. Jasmine
    Jasmine Member
    Nov 19, 2013
    46
    5
    8
    Surface 3 (Atom)
    Yep, the same thing happens to me too. Mine won't update unless I restart.
  5. Dane
    Dane Member
    Nov 8, 2013
    41
    4
    8
    Toronto
how to tell if power cover is charging surface pro 2
microsoft surface 2 stops charging
microsoft surface charging issues
microsoft surface stops charging
surface 2 charging issues
surface pro 2 charging issues
surface pro 2 plugged in not charging
surface pro 2 stops charging
surface pro stops charging
