Connecting SP3 to a VGA KVM switch causes screen blinking?
Discussion in 'Microsoft Surface Pro 3' started by btrcp2000, Jul 14, 2014.
  1. btrcp2000
    btrcp2000 New Member
    Jul 14, 2014
    8
    0
    Hello-
    Need to be able to switch between older tech work laptop and SP3. I have done this in the past with my Dell XPS12, a mini display vga adapter, and an IOGEAR Extreme GCS1732 2 port KVM. The KVM will not output anything to the monitor, and just causes the SP3's screen to blink. If I connect the SP3 directly to the monitor, it works as expected, so obviously there is something about the switch it doesn't like. Any ideas?
    tia
  2. kozak79
    kozak79 Active Member
    Nov 15, 2013
    296
    61
    28
    I think the signal form the Surface Pro is weaker. Where I teach I tried to plug the overhead projector to my SP2 (it works fine from the workstation I have), but the length of the cable seems to be an issue. It would work, but there were horizontal line artifacts on the projector that were not there from the workstation computer. The signal might be too weak for the KVM. You may need a powered KVM that boosts the signal, those are pretty pricey.
  3. malberttoo
    malberttoo Super Moderator Staff Member
    Feb 26, 2013
    2,255
    428
    83
    Alaska
    It may not like the resolution of the SP3...
  4. btrcp2000
    Jul 14, 2014
    8
    0
    The KVM is powered (iogear gcs1732). Resolution was a good thought, so before plugging in the mini DP, I lowered it all the way to 1024 by 768, same result with a blinking SP3 screen. The monitor acts like nothing is plugged in at all, so it must be something between the SP3 and the kvm
  5. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Try restaring your Surface with everything plugged in. Watch the monitor to see if the color of the power light changes.
  6. btrcp2000
    Jul 14, 2014
    8
    0
    same blinky screen once it boots up, no recognition of anything by the monitor
  7. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    You should at least have seen the light go from standby, typically orange, to blue. Your KVM or cables may be a problem.
  8. RottenMutt
    RottenMutt Member
    Jun 21, 2014
    54
    8
    Ft Worth
    display port doesn't put out VGA, it would have to be the display port to VGA adapter...
  9. btrcp2000
    Jul 14, 2014
    8
    0
    Dp/Vga Adapter works fine connected directly to the monitor. It's the switch, confirmed with a test on a similar model at home. Same thing happened.
  10. RottenMutt
    RottenMutt Member
    Jun 21, 2014
    54
    8
    Ft Worth
    the try your display port to vga adapter using another device that has display port adapter.
    you do realize that display port to vga adapters are active, not passive; which leaves the problem to be the adapter...
  11. btrcp2000
    Jul 14, 2014
    8
    0
    No, did not realize that and barely know what it means. :). But if that's the case, why would the adapter work if directly connected to the monitor? I called iogear, who said the switch is not compatible with dp, so I ordered a dp switch from amazon, will report back in case anyone else runs into this. Also wound up swapping the sp3 because it had an issue with standby vs hibernate that Microsoft store couldn't figure out, so they gave me a new one even though I bought@ best buy. Good customer service.
connecting keyboard to windows surface 2causes display screen to blink
connecting surface pro 3 to kvm
io gear kvm causes monitor to blink
kvm for microsoft surface
kvm monitor flashing
kvm switch keeps blanking screen
monitor starts blinking when connected to iogear kvm
surface pro kvm
vga adaptor surfacebook screen flashing
when using kva switch monitor screen blinks
