D: drive turning into E: drive
Discussion in 'Microsoft Surface Pro 2' started by Tsurugaya, Feb 3, 2014.
  1. Tsurugaya
    Tsurugaya Active Member
    Jan 23, 2014
    396
    28
    28
    Using VHD I turned my microSDcard into a fixed D: drive so I could install small utilities and other programs on it and set up a start event to mount it. Suddenly it no longer automatically mounts and when I mount it manually it turns into drive E:, hence some utilities no longer run since they are expected to run from D:
    Any idea what has gone wrong?
  2. bertopl
    bertopl Active Member
    Feb 10, 2013
    176
    29
    28
    Las Vegas, NV
    have no idea why it would change, mine never has. did you try going into disk management from the control panel? if you right click a drive, you can choose "Change Drive Letter and Paths"
microsoft surface d drive
ms surface d drive
windows surface d drive
