Desktop swipe gestures for IE
Discussion in 'Microsoft Surface Pro 3' started by thejoker1993, Sep 16, 2014.
  1. thejoker1993
    thejoker1993 Member
    Sep 18, 2013
    46
    2
    8
    Is it possible to enable swiping like it is in the metro version. Using either touch or mouse to go back and forward. There is nothing in advanced settings.
  2. Diego Madrigali
    Diego Madrigali Member
    Aug 2, 2014
    31
    5
    8
    I couldnt find it either
  3. kundas1
    kundas1 Super Moderator Staff Member
    Dec 4, 2013
    1,663
    300
    83
    no, you cannot use swipe motion in desktop IE11 that's why they made a Metro version or else they would have just left out metro IE11 and enabled it in the desktop. ;)
  4. ybahman
    ybahman Member
    Feb 10, 2014
    40
    5
    8
  5. thejoker1993
    thejoker1993 Member
    Sep 18, 2013
    46
    2
    8
    ^ That would work with Desktop IE?
    Thank you!
  6. ybahman
    ybahman Member
    Feb 10, 2014
    40
    5
    8
    yup! It'll work with any browser really because you can map a gesture to any keyboard shortcut. In this case, the keyboard shortcut you're looking for is Alt+LeftArrow. But TouchMe has a built in version of this called something to the tune of "Browser: Back"
    The only difference is that you can't map single finger gestures, so you'd have to map it a little differently. By default TouchMe maps 2 Finger Swipe Right to "Browser: Back"
    Let me know how it works!
gestures for ie desktop
can i use-swipe gestures in ie11 in desktop mode surface
enable swiping motion on internet explorer for the desktop
gestures ie11 desktop
how to swipe back and forward surface 3
ie11 desktop mode gestures
ie11 desktop version touch swipe
ie11 gestures 2015
surface ie desktop swipe
surface pro 3 ie 11 swipe desktop
