Difference between surface pro 2 128 gb and a surface (8 pro) 128g
Discussion in 'Microsoft Surface Pro' started by Reiki gal, Dec 7, 2014.
  1. Reiki gal
    Reiki gal New Member
    Dec 7, 2014
    0
    I was going to bid on a surface pro 2 128gb and when I did they had put misinformation about it and it was really a surface pro 128 gb what is the difference the pro 2 will be for my son in year 7
  2. daniielrp
    daniielrp Active Member
    Oct 26, 2013
    693
    133
    43
    Preston, UK
    Just the processor, pretty much everything else is the same. However, the better processor meant much better battery life for the SP2.
  3. toaf
    toaf Member
    Jul 9, 2014
    231
    22
    18
    infront of my surface you silly person
    SPro2
    ya SP2 battery last longer. but SP1 was still nice. your son is 7? dont know if i would trust a 7 year old with not dropping it
  4. drolem
    drolem Active Member
    Aug 9, 2013
    293
    36
    28
    98052
    Better battery life and a 2 positions kick-stand.
  5. jaekqubp
    jaekqubp Member
    Jun 20, 2014
    48
    7
    8
    SPro
    The 1st generation Surface Pro uses 3rd generation i5 technology, whereas the 2nd generation Surface Pro uses the 4th generation i5 technology. This equates to slightly increased CPU performance, overall, a significantly improved GPU, and most of all, vastly improved battery life. In addition, I believe that the Pro 2 has some other small differences, such as increased resolution capability, afforded by the updated GPU. I could be incorrect in that assertion, however. There is the additional position on the kick-stand, as well, but if you are giving it to a seven-year-old, I would recommend a protective case, anyway.
    Finally, if the seller listed the item deceptively or incorrectly, you have recourse to decline the purchase. Feel free to reply, or private message if you have any further questions regarding that issue.
    Good luck.
  6. daniielrp
    Oct 26, 2013
    693
    133
    43
    Preston, UK
    Year 7
    That's the first year of high school, so he'll be 11 - 12.
  7. jaekqubp
    jaekqubp Member
    Jun 20, 2014
    48
    7
    8
    SPro
    My mistake. That makes more sense.
    OP, let us know how it works out or if you have further questions.
difference between surface and surface pro
