Does the battery on screen get charged by base?
Discussion in 'Microsoft Surface Book' started by bangsters, Nov 6, 2015.
  1. bangsters
    bangsters Member
    Apr 15, 2013
    172
    16
    18
    Will the battery on the base charge the battery in the screen? Like if I'm on clipboard mode and I deplete the battery, will plugging it back to the base charge the battery in the clipboard, if I don't have the charger with me?
    Don't have the book yet, waiting for mine, but I'm curious if the base can charge to clipboard.
    Thanks!!
  2. Niterider4
    Niterider4 Active Member
    Oct 29, 2015
    208
    56
    28
    Surface Book
    Nope, gotta have a charger. But you can plug the charger into either unit.
    bangsters likes this.
  3. GreyFox7
    Jul 27, 2014
    6,907
    1,385
    113
    MS deemed the energy loss from transferring one to the other a waste of battery life.
  4. bangsters
    bangsters Member
    Apr 15, 2013
    172
    16
    18
    Bummer. But if the clipboard drains, I can just connect it to the base then, and while it won't charge the battery in the clipboard it should at least let me use it in laptop mode? If not then I might need to get a second charger hehe...
    ...oh and my book should be getting to me soon...hopefully no more delays
surface book screen charge
