Email Problems
Discussion in 'Microsoft Surface Help' started by sarah, Apr 6, 2013.
  1. sarah
    sarah New Member
    Apr 6, 2013
    4
    0
    0
    Any idea re sending emails from other accounts? Surface will not send or recieve emails from a demon account, despite Microsoft and demon saying it should, nor will it do so with a domain name account - am i restricted to gmail etc?
  2. bosamar
    bosamar Well-Known Member
    Nov 10, 2012
    1,453
    78
    48
    RT
    Are you using IMAP?
  3. sarah
    sarah New Member
    Apr 6, 2013
    4
    0
    0
    yes, that was the plan
  4. bosamar
    Nov 10, 2012
    1,453
    78
    48
    RT
    I setup email from three domains and they all work fine. Are you sure you've got the incoming and outgoing server names set correct? The only other things could be are misspelled addresses and/or passwords.
  5. sarah
    sarah New Member
    Apr 6, 2013
    4
    0
    0
    I'll double check, something is not right as both accounts should to all intents work, but its defeating me plus the IT support so far - did the server port numbers get automatically provided or did you input them?
  6. bosamar
    Nov 10, 2012
    1,453
    78
    48
    RT
    My ISP is Bluehost and their help section told me what Port numbers to input.
  7. Omni
    Omni Active Member
    Oct 27, 2012
    387
    35
    28
    UK
    I found the default ports on the surface were wrong for my provider. Worth a check...
  8. sarah
    sarah New Member
    Apr 6, 2013
    4
    0
    0
    thanks all, have a session with an it expert today to try and get things sorted, will update after that
  9. cali
    cali Member
    Jun 19, 2012
    542
    22
    18
    Hope you got this worked out.
bluehost email settings for microsoft surface pro
bluehost mail
bluehost webmail on surface
bluehost yahoo mail
email account on surface problem
microsoft surface email problems
microsoft surface mail problems s
microsoft surface problem outgoing email
microsoft surface webmail issues
problem in sending mails in microsoft tablet
