External battery
Discussion in 'Microsoft Surface Pro 4' started by Mirkof, Jul 31, 2017.
  1. Mirkof
    Mirkof New Member
    Jul 31, 2017
    2
    3
    Hi,
    I looked for a similar thread but apparently this is the first one. I need to use my Surface at school when I can't use the original charger, so I thought that an external battery would be perfect. Anyway i found 1 battery for Surface on the Internet but I'm not really convinced it works.
    Do you have any suggestions ?
    Thanks in advance
  2. jnjroach
    Nov 9, 2012
    7,965
    1,884
    113
    Seattle, WA USA
    SurfaceProX
  3. Cuchulainn
    Cuchulainn Member
    Jun 23, 2017
    68
    4
    8
    Denver, Co
    SPro
    I am thinking of this one myself, not cheap, but cheap ones make me nervous when connected to an expensive device, such as this.
  4. herbertlemons
    herbertlemons New Member
    May 14, 2017
    5
    3
  5. hughlle
    Jul 7, 2014
    3,116
    473
    83
    I've used an sp3 and sp4 at university for the past 3 years and have never had a single reason to consider a battery pack. Then again, I used mine purely for work, I imagine many want to use it frequently for Facebook, games etc.
  6. Cuchulainn
    Cuchulainn Member
    Jun 23, 2017
    68
    4
    8
    Denver, Co
    SPro
    What does Facebook and games have to do with anything?
  7. hughlle
    Jul 7, 2014
    3,116
    473
    83
    They were simply examples, but pretty much everything. How you use the device will determine the battery life you can get. I pointed out that for pure work use, i.e turn it off after class, not spending an hour at lunch browsing forums, facebook, playing some counter strike etc, the internal battery on my sp4 is more than enough to get me through a day of university (5-8 hours of onenote or word).
    My point in short, depending on how you intend to use the device, there may be no need to spend additional money on an external battery.
  8. Cuchulainn
    Cuchulainn Member
    Jun 23, 2017
    68
    4
    8
    Denver, Co
    SPro
    OK, gotcha. I wasn't quite following and wasn't sure if you were suggesting that Facebook and game use was the only reason you would need an external battery.
    I am actually not a frequent FB user, nor do I have any games installed. I deleted everything right down to MS solitaire. But I do find that even on my new SP2017, which is supposed to have much better battery life, that I am tanking it by the end of the day. I find I am only getting 5-6 hours battery in an 8+ hour day.
    I know the OP mentioned using it for school. I can't really speak for that use case. I am often using mine outside and in brightly lit environments. I think screen brightness the largest contributing factors to my short battery life. Perhaps the software as well. I have to combine photos and drawings into reports ands often the machine is working pretty hard, based on how warm it gets.
    The car charger helps some, but it doesn't charge very quickly. I am thinking I could probably attach an external battery to the outside of the case.
external battery in surface pro
external battery surface pro 4
