External Monitor for S Pro3
surfdock
Hi welcome to the forums. A monitor is really a personal preference based on the size you want and what you can afford and what features are valuable to you.
For painting/illustration, I think the monitor you chose is fine. However, if you go with a slightly smaller panel size (21.5") it will match up much better with the Surface Pro. For more info on choices specific to the Surface Pro, please see: http://blogs.msdn.com/b/danchar/arc...on-with-surface-pro-3-dpi-scaling-tweaks.aspx
