External optical drive?
Discussion in 'Microsoft Surface Accessories' started by Angel, May 29, 2013.
  1. Angel
    Angel Member
    May 20, 2013
    67
    3
    8
    Any suggestions for a good external optical drive as I have programs I will need to load.
  2. riggi
    riggi Member
    Mar 29, 2013
    147
    25
    18
    Any USB drive should work.
    I have 2 lying around from the last 2 laptops I bought that didn't have optical drives and the shop/OEM threw them in for "free".
    1 Samsung, 1 Dell.
    Both work fine.
    I keep one at home and 1 at work to use with my laptop and SP.
    Unless you are using it a lot (in which case you probably wouldn't have bought a SP) I'd just get the cheapest you can find. I use mine 3 or 4 times a year, if that.
  3. TeknoBlast
    TeknoBlast Active Member
    Oct 16, 2012
    764
    134
    43
    Irving, TX
    Same here, I bought an external dvd drive for about $15 and it has worked great on my non-dvd devices.
  4. Angel
    Angel Member
    May 20, 2013
    67
    3
    8
    So you don't have to have a 3.0?
  5. bertopl
    bertopl Active Member
    Feb 10, 2013
    176
    29
    28
    Las Vegas, NV
    also, if just using it to load a few programs, if you have other computers on your home network with an optical drive, you can share the drive and install from there, no? or maybe just copy the contents onto a usb drive should work to install stuff too.
    1 person likes this.
  6. Angel
    Angel Member
    May 20, 2013
    67
    3
    8
    Yeah I wanted to do that but the drive on my laptop won't read ISO software, tried everything it simply won't recognize it. So if the pro doesn't require a 3.0 drive then I will buy a decent but cheap version to load my programs and any new software will be downloads or flash load able. Could anyone confirm the 3.0 issue? Thanks a lot everyone!
  7. J515OP
    J515OP Super Moderator
    Jun 19, 2012
    2,177
    262
    0
    Northern CA
    RT
    You don't need a USB 3.0 device. USB 3.0 is backwards compatible and USB 2.0 devices work just fine :)
  8. Angel
    Angel Member
    May 20, 2013
    67
    3
    8
    Thank you so much
  9. ORB1T4L
    ORB1T4L New Member
    Jun 5, 2013
    2
    0
    0
    Hi !
    Can I use an external optical drive to reinstall W8 Pro if something goes wrong with the pre-installed version ?
    Thanks
  10. Buelligan
    Buelligan Member
    Mar 25, 2013
    53
    23
    8
    Hedgesville, WV
    SPro
    Yeah, I was going to buy and external drive also, but discovered that I could just "map a network drive" to the one in my gaming tower and it works perfectly!. On my home network of course. So until I have the need for a disk drive on the go that works for me.
external optical drive for surface
external optical drive for surface pro
external optical drive for surface pro 3
optical drive surface pro 3
surface pro 3 external optical drive
surface pro 3 optical drive
surface pro optical drive
