Fan kicking into high gear when viewing certain sites in modern IE
nnthemperor
Hi guys, lately I've noticed the CPU usage spike up and the fan kicking into high gear when I'm browsing the Engages.com site in modern internet explorer. It really makes the pages loaded very slowly. Wonder if anyone experienced this too.
GreyFox7
Super Moderator
Please describe the purpose and nature of the site. as much as id like to analyze this... I'm not that trusting.
Logically, if browsing other sites is fine and browsing this specific site is not fine it's a pretty safe bet it's the site even if it seems to run fine in a different browser. Inefficient code is the most frequently encountered problem but it could be very poorly coded or incorrectly implementing some features or might even be malicious.
GreyFox7
Super Moderator
Definitely report the problem to the site. there's some horrendous ADs on there :)
First try adding tracking protection lists using the Desktop IE which will run in MUI IE also.
Otherwise look at using the Winhelp hosts file solution... most effective AD and Malware blocker ...
I just have the file installed and an exclusion in antivirus nothing else,
