Solved Fast SD Card Recommendation
Discussion in 'Microsoft Surface Pro 4' started by Sid Gup12, Dec 21, 2015.
  1. Sid Gup12
    Sid Gup12 New Member
    Aug 28, 2014
    10
    Hello all,
    I just got my new SP4 and deciding which SD card the community prefers. I am debating between these two:
    1. SanDisk Extreme 64GB UHS-1
    Amazon.com: SanDisk Extreme 64GB MicroSDXC UHS-1 Card with Adapter (SDSQXNE-064G-GN6MA): Computers & Accessories (around $33)
    2. Samsung 64GB PRO
    Amazon.com: Samsung 64GB PRO SDXC Memory Card - Class 10 (MB-SG64D/AM): Computers & Accessories (around $45)
    3. Something faster/better? From what I could find on the interwebs, UHS-1 is fastest.
    Thanks
    Update: I eventually got a Samsung PRO+ (like this) on community's recommendation. See my post HERE
  2. GreyFox7
    Jul 27, 2014
    6,789
    1,355
    113
    The two are NOT equivalent. the Samsung you linked is NOT a micro SD card.
    You need this one... http://www.amazon.com/dp/B00IVPU88U
    The Samsung pro is a higher class card than the SanDisk extreme if you want to compare head to head you should look at the SanDisk extreme Pro
    Either way I'll take the Samsung Pro.
  3. Nspyr
    Nspyr Member
    Dec 8, 2015
    38
    0
    6
    I have the Samsung EVO 128. Is this any good or should I get the pro.
  4. GreyFox7
    Jul 27, 2014
    6,789
    1,355
    113
    AFAIK Samsung has not released a Pro 128gb yet. The Evo is not bad (48mbps read), They have an Evo+ with 80mbps read/20mbps write. The 64gb Pro is 90mbps read/80mbps write.
  5. 3rdschulz
    3rdschulz New Member
    Nov 28, 2015
    20
    0
    I am also interested in what micro SD cards people recommend for their SP4. I have read good reviews about the Samsung Evo. Not to stray off topic but for the higher speed micro SD cards mentioned above, what will these speeds effect? For example would a game stored on the micro sd card be affected by its speed after opening it once it had loaded?
  6. GreyFox7
    Jul 27, 2014
    6,789
    1,355
    113
    I have no idea if a game would write/read the card while playing. If it does than the speed might make a difference. The way to find out it to launch Resource monitor and on the Disk tab sort by Total bytes per second, Read bps, Write bps (one at a time) and look at the program(s) with the highest activity. You can see the process and the files being accessed. If something you're interested in has high activity then speed matters and slow speed kills.
  7. Nspyr
    Nspyr Member
    Dec 8, 2015
    38
    0
    6
    I don't know about games but I tried to use it for video editing and it's pretty slow. I think its because the read/write speed is not like a ssd drive.
  8. smar
    smar Member
    Dec 27, 2013
    49
    11
    8
    London
    I have tried both a Samsung 64Gb Pro UHS-I, which is rated at 90Mb read/80Mb write, and a Lexar 128Gb Professional UHS-II, which is rated at 150Mb/s read.
    On my SP4, both the cards max out at about 85Mb/s read speed when using the internal SD card slot. I have pushed the Lexar to 140Mb/s or so by using the provided USB 3 adapter instead.
    Bottom line is that if your use of the card is only on an SP4, you're better of buying the cheaper UHS-I card.
    PS I run a Windows 7 virtual machine on my microsd card. Bit slow but certainly usable.
  9. TonyJackson
    TonyJackson New Member
    Nov 27, 2015
    12
    2
    3
    Hi, Sandisk 128Gb Class 10, 90/80MBs should be quite fast enough. I am using one.
  10. Zkyevolved
    Zkyevolved Active Member
    Dec 5, 2013
    242
    28
    28
    Are you actually getting those speeds? Can you do a speed test?
  11. TonyJackson
    Nov 27, 2015
    12
    2
    3
    Actually for large files I got 45-60 to write (according to Windows transferring speeds), so it's very acceptable. However, small files will spend much more time.
    Zkyevolved likes this.
  12. Zkyevolved
    Dec 5, 2013
    242
    28
    28
    Of course. Damn that 1 file per queue request limit on usb and micro SD!
micro sd card recommendation for surface pro 4
recommendation for surface pro 4 sd card
