frozen screen surface pro3
Discussion in 'Microsoft Surface Pro 3' started by Kan Chandra, Oct 30, 2014.
  1. Kan Chandra
    Kan Chandra New Member
    Sep 28, 2014
    2
    0
    My new surface pro3 I7 512 GB has just frozen. I could not shut down or restart. Help needed urgently.
  2. GreyFox7
    Jul 27, 2014
    6,893
    1,384
    113
  3. fifl
    fifl New Member
    Jan 7, 2014
    20
    0
    Same happend to me on tuesday. I was only using onenote2013 for notetaking. The only thing that worked was powerbutton+volumedown at the same time for.. 5sek?
  4. Kan Chandra
    Sep 28, 2014
    2
    0
    Thanks Greyfox 7 & fifi. It worked by holding the on switch for 30secs.
  5. keanchee
    keanchee New Member
    Oct 29, 2015
    0
    I have same issue, and i found out is the SD Card spoil. After i remove the SD Card no more frozen screen. But i don't know why it will affect the screen frozen...
  6. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Welcome to the forum
    You say the screen was frozen but the system was probably busy looking at the SD card. What have you stored on the SD card? If it happens again you may want to check the card with a surface test at the minimum.
frozen surface pro 3
my surface pro 3 is frozen
surface 3 frozen
surface frozen screen
surface pro 3 frozen
surface pro 3 frozen on surface screen
surface pro 3 frozen screen
surface pro frozen
surface pro frozen screen
surface pro screen frozen
