Solved Houston we have a problem.. Pen won't write all the way to the edge of the screen
Discussion in 'Microsoft Surface Pro 3' started by Mikewired, Sep 2, 2014.
  1. Mikewired
    Mikewired Member
    Aug 30, 2014
    148
    17
    18
    I noticed today that the pen will not write all the way to the right side of the screen in onenote portrait mode. When the pen gets about a half inch from the edge of the screen a line appears from the pen tip to the bottom of the screen?
  2. ctitanic
    ctitanic Well-Known Member
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    I can't replicate it.
    unruledboy likes this.
  3. Tsurugaya
    Tsurugaya Active Member
    Jan 23, 2014
    396
    28
    28
    I have a similar problem, about a 1,5 cm dead zone from about 1 cm in on the left side in portrait. I can see it on the hover cursor on the desktop as well. So this is clearly a manufacturing slipup.
  4. ctitanic
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Have you tried calibrating the screen?
  5. Mikewired
    Mikewired Member
    Aug 30, 2014
    148
    17
    18
    Calibrating did not work, it would not let the pen cursor go into the corners. But I did click the reset calibration button. I was then asked if I wanted to erase all calibration data. That did the trick it is now back to working properly.
  6. GreyFox7
    Jul 27, 2014
    6,772
    1,349
    113
    So you skipped step three the first time but now that you've done it everything is fine.
    Huston to space cadet check your calibration ;)
  7. ctitanic
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    So you missed step 3!
  8. Mikewired
    Mikewired Member
    Aug 30, 2014
    148
    17
    18
    Yep I guess I did. I was reading from my phone at the time
  9. ctitanic
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Could you change the status of the thread to solved?;)
surface 3 pen wont write
surface pen connected but wont write
surface pen opens one note but wont write
surface pen opens onenote but wont write
surface pen will not write
surface pen wont write
surface pen wont write but opens onenote
surface pro 3 pen wont write
surface pro 4 pen wont write but opens onenote
surface pro pen will not write but one note opens
