icon issue
Discussion in 'Microsoft Surface Pro 2' started by stevenrossvanduyn, Feb 15, 2014.
  1. stevenrossvanduyn
    stevenrossvanduyn Member
    Jan 23, 2014
    69
    9
    8
    Sometimes when i startup or go into desktop mode i find my icons are moved around
    Very annoying
    How to stop this from happening
  2. Jasmine
    Jasmine Member
    Nov 19, 2013
    46
    5
    8
    Surface 3 (Atom)
    I actually noticed this 2 or 3 times with my first SP2. Ended up returning it and waiting for them to restock.
    I honestly have no idea how to solve it, but hopefully someone else does.
  3. Dayton
    Dayton Member
    Dec 19, 2013
    75
    2
    8
    Size of icons, align or auto? I use small with align to grid, icons have always remained as I've left them.
  4. kozak79
    kozak79 Active Member
    Nov 15, 2013
    296
    61
    28
    This could happen if at some point there was a resolution change. If the resolution changes to lower than what the icons are layed out to, they will be repositioned to fit the new resolution. Some applications will change resolution, like games. I have starcraft 2 changing resolution to 720p. If this is the issue you are having, you can make sure to keep your icons in the upper left so they keep withing the lower resolution as well.
    Or it could be some other weird thing :)
  5. jackh
    jackh Member
    Jan 12, 2014
    44
    0
    6
    Do a Google search for this little utility called ICONOID --been using it for years--It will keep your Icons where you put them and has a few other nice features..
    Jack
  6. jollywombat
    jollywombat Member
    Nov 25, 2013
    171
    22
    18
    NY, USA
    SPro2
    Yah, anything that changes your full screen resolution can cause this like games, using external monitors, etc.
  7. olimjj
    olimjj Active Member
    Mar 27, 2013
    550
    113
    43
    Where no man has gone before.
    You might want to consider pinning the majority, if not all of your icons on the taskbar.
surface pro 2 device icons
