In Search of a Small USB 3 Powered Hub w Ethernet for SP3
Discussion in 'Surface - Peripherals' started by khit, Mar 25, 2016.
  1. khit
    khit New Member
    Jul 13, 2014
    16
    0
    Im looking for a small powered USB 3 Hub with Ethernet to use on an SP3. I've had a Diamond MM one for a couple of years that has started to fall apart, so I'd like something a bit better built. Are there any powered hubs that could use the USB port on the SP3 charge block to provide power instead of a separate wall wart? would like something very portable.
  2. Edwin009
    Edwin009 New Member
    Mar 4, 2016
    3
    0
    Other
    Hello Khit,
    You can try one of these 2 options: HT-UE01 3-Port USB 3.0 HUB with 10/100/1000 Gigabit Ethernet LAN Network Adapter.
    Or you can try the Belkin USB 3.0 3-Port Hub with Gigabit Ethernet Adapter.
    Hopefully they would work with your device.
  3. agt499
    agt499 Member
    Jul 17, 2014
    153
    24
    18
    I've never seen one, but that's a great idea. I think I may break out the soldering iron, as the necessary wiring would be trivial, and if you get the length just right it could be very very tidy. Let us know if you find one!
  4. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    I have the Belkin with 3 USB 3.o on thew side and a GB connector on the end. Works great. Got it at the MS Store when I got my SP4.
  5. khit
    khit New Member
    Jul 13, 2014
    16
    0
    Thanks for the replies, but it doesn't appear that either one of these take external power. I've noticed on more than one occasion using USB drives with my SP3 and the current hub where drives will fall offline. Looking at various threads here I suspect I'm running into the under powered USB port thing on the SP3 which is why I'm looking for something with its own power but still portable enough to throw in my bag.
  6. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    You may want to consider getting the dock.
  7. khit
    khit New Member
    Jul 13, 2014
    16
    0
    I had considered the dock but felt it was too big and overkill for what Im needing - I don't need to have display out etc. On most days I don't even need the Ethernet functionality, but I do rely on the USB quite a bit.
  8. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Another option, get a powered USB HUB and a USB Ethernet adapter you can plug into it when needed.
  9. khit
    khit New Member
    Jul 13, 2014
    16
    0
    Yes, exactly what I had been thinking, now if I can only find that small powered USB hub :)
  10. jrioux
    jrioux Active Member
    Dec 12, 2013
    424
    48
    28
    California's Central Coast
    Have you looked at the various Surface Pro docks from eTauro (www.etauro.com)? They look very interesting, but I haven't tried them.
