Intermittent TypeCover
Discussion in 'Microsoft Surface Pro' started by hifilistener, Apr 25, 2013.
  1. hifilistener
    hifilistener New Member
    Feb 21, 2013
    8
    0
    0
    Ohio
    Hello,
    I have been experiencing recently (after the last firmware change) an issue where I will be in the middle of using my TypeCover and it will totally STOP functioning. The Screen will still respond. I have to disconnect and reconnect the TypeCover and it starts functioning again.
    Is this a known issue?
    Thanks,
    Justin
  2. mitchellvii
    mitchellvii Well-Known Member
    Mar 30, 2013
    2,483
    559
    113
    Charlotte, NC
    Download fresh copy of "Trackpad Settings" from Store. This fixes a keyboard bug caused by a recent update. It also allows you to turn off/on your trackpad.
  3. J515OP
    J515OP Super Moderator
    Jun 19, 2012
    2,177
    262
    0
    Northern CA
    RT
    Hi Justin, this has been an ongoing problem and changed over time. In the best case it is just a software glitch that you can overcome with updates and settings. In the worst case scenario you may have a faulty Type cover to return. Take a look around the forum and see if any of the tips or adjustments work for you or if you need to consider a return.
  4. DOTTAT
    DOTTAT New Member
    Feb 25, 2013
    16
    3
    Mine and others posted here ended being the surface tab itself. Try taking it to a store to see if other keyboards work when yours doesnt.
intermittent stop woring type cover surface
microsoft surface keyboard intermittent
surface keyboard works intermittently
surface pro 3 intermittent keyboard problem
surface pro 3 keyboard intermittent
surface pro 3 no touch pad settings intermittent
surface pro 3 typecover working intermittently
surface pro keyboard intermittent
surface pro keyboard works intermitant
