is there a way to print from RT
Discussion in 'Microsoft Surface General Discussion' started by capdad, Feb 11, 2013.
  1. capdad
    capdad New Member
    Feb 6, 2013
    22
    2
    0
    I have a printer on my home network, hooked up via network connection. Is there a way to set up the RT so I can print from it?
  2. bosamar
    bosamar Well-Known Member
    Nov 10, 2012
    1,453
    78
    48
    RT
    From Metro type/enter Control Panel > Devices and Printers > Add a printer > it will search for available printers > select one > Next > following the instructions
  3. guitar1969
    guitar1969 New Member
    Nov 3, 2012
    117
    8
    0
    If it were that easy. . . .
    The problem is that many printers are not compatible with WinRt and the Windows Update service for the printer database is non existante (Will not find your printer). I was able to get one of my printers working but had to use a generic variant for it after alot of trial and air. Still hoping MS addresses this issue so I can print at work someday.
  4. bosamar
    Nov 10, 2012
    1,453
    78
    48
    RT
    Yup, I'm in the same boat as you. My HP wireless printer uses a generic driver, but hey it works. Something I couldn't do with my iPadv1.
  5. Rallicat
    Rallicat New Member
    Nov 13, 2012
    91
    14
    0
    Whether you have a good printing experience or a bad one depends on the printer.
    I bought a new HP OfficeJet all-in-one wireless printer & scanner, which I'd first checked was compatible with Windows 8 & RT. Not only did it 'just work' with my Surface, but it even discovered and installed the driver automatically without being prompted (my network was set to trusted, so it just found the printer after I'd set it up and did the rest for me). It even automatically downloaded the HP printer app, and HP wireless scanning app from the store!
    It might mean shelling out a bit of money, but a new printer that's verified compatible with RT will give a very good printing experience, and even scanning experience if the vendor has an app for it :)
  6. zombie
    zombie New Member
    Feb 6, 2013
    2
    0
    0
    My brother laser printer worked just fine, just had to go in and add new printer. The driver was built in.
    Of course, I did my research before I purchased this printer (was on sale for $80 as well, is $99 currently) and RT wasn't out then.
    From what I have been reading, HP is very compatible, and other printers are spotty at best. Depending on the printer you want/have, you need to check the website of that printer manufacturer. If they say it is supported, the driver will be built in. If they don't mention it, either buy a new printer or hope they support it in the future.
  7. Sin
    Sin New Member
    Nov 14, 2012
    470
    32
    0
    Connecticut, USA
    RT
    I have not been impressed with printer and scanner manufacturers. They appear to drop support in an attempt to get you to purchase a new model despite have a perfectly good device that only needs a driver. Won't say that they are all doing that, but my contact with both Canon and Epson was nothing short of frustrating. I'll sort out my printer driver through trial and error. Found on that partially works but doesn't print from everything. I'm sure there is one out there, but Canon doesn't seem to want to bother.
  8. capdad
    capdad New Member
    Feb 6, 2013
    22
    2
    0
    I chose an HP variant and it seems to be working. At least it printed a test page. Thanks All
  9. jnjroach
    Nov 9, 2012
    7,647
    1,821
    113
    Seattle, WA USA
    SPro
    My Brother Color Laser works fine from my RT device, the only feature (which is a biggie) is I lose is two sided printing...see if you Printer OEM has a generic PCL6 driver and it should work...
  10. J515OP
    J515OP Super Moderator
    Jun 19, 2012
    2,177
    262
    0
    Northern CA
    RT
    This isn't very promising considering I have an unsupported Canon :(
  11. guitar1969
    Nov 3, 2012
    117
    8
    0
    Same boat. I have a Canon color printer at work that the company just bought and I cannot get it to work. If I told them to go out and buy another printer for my RT they would laugh at me.
  12. Heino
    Heino New Member
    Nov 20, 2012
    4
    3
    AW: is there a way to print from RT
    Check printer settings in desktop mode. There is a register where you tell windows that your printer can do duplex. I also have a brother printer and could enable it there. Was as frustrated as you at first.
    1 person likes this.
how to print from surface rt
how to set up printer on surface rt
how to set up printer surface rt
how to setup a printer winrt
how to setup printer surface rt
howto set up printer on windows surface rt
not able to print from surface
surface rt mx700
surface rt print to mx700 canon
