Hey Guys, So since the latest firmware update i have noticed that my Surface Pro 2 is acting a little erratically. The only power options i ever modified was that the lid-closing action is disabled and that it sleeps after 5 minutes (i move between meetings allot and want to retain lync conversations on the go and not loose the "flow" of them by going offline as i move around the office/meetings/buildings. However i have noticed a few times that that the Pro simply does-not sleep after the 5 minute threshold. Also a few times when i have popped the unit in my bag (After a full charge) and pulled it out an hour later after driving home the unit is warm to the touch, the fans are spinning like crazy and its drained its battery :S I ran the Power Report and see nothing amazingly worrying in there that leads me to believe there is a configuration issue. I would greatly appreciate a second pair of eyes on this to make sure i am not being a numpty though Code: Power Efficiency Diagnostics Report Computer Name TOMSSURFACEPRO Scan Time 2013-12-16T20:54:07Z Scan Duration 60 seconds System Manufacturer Microsoft Corporation System Product Name Surface Pro 2 BIOS Date 11/08/2013 BIOS Version 2.04.0250 OS Build 9600 Platform Role PlatformRoleSlate Plugged In false Process Count 65 Thread Count 1015 Report GUID {5553e2c4-830c-4d1d-906a-437422bd5814} Analysis Results Errors Power Policy:Sleep timeout is disabled (Plugged In) The computer is not configured to automatically sleep after a period of inactivity. Power Policy:Disk idle is disabled (Plugged In) The disk is not configured to turn off after a period of disk inactivity. USB Suspend:USB Device not Entering Selective Suspend This device did not enter the USB Selective Suspend state. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping. Device Name USB Composite Device Host Controller ID PCI\VEN_8086&DEV_9C31 Host Controller Location PCI bus 0, device 20, function 0 Device ID USB\VID_1286&PID_2044 Port Path 2 USB Suspend:USB Device not Entering Selective Suspend This device did not enter the USB Selective Suspend state. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping. Device Name USB Composite Device Host Controller ID PCI\VEN_8086&DEV_9C31 Host Controller Location PCI bus 0, device 20, function 0 Device ID USB\VID_045E&PID_07A9 Port Path 3 CPU Utilisation:Processor utilisation is high The average processor utilisation during the trace was high. The system will consume less power when the average processor utilisation is very low. Review processor utilisation for individual processes to determine which applications and services contribute the most to total processor utilisation. Average Utilisation (%) 42.03 Warnings Platform Timer Resolution:Platform Timer Resolution The default platform timer resolution is 15.6 ms (15625000 ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations. Current Timer Resolution (100 ns units) 10007 Maximum Timer Period (100 ns units) 156250 Platform Timer Resolution:Outstanding Timer Request A program or service has requested a timer resolution smaller than the platform maximum timer resolution. Requested Period 10000 Requesting Process ID 3392 Requesting Process Path \Device\HarddiskVolume4\Program Files (x86)\Microsoft Office\Office15\OUTLOOK.EXE Power Policy:Display timeout is long (Plugged In) The display is configured to turn off after longer than 10 minutes. Timeout (seconds) 1200 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name System PID 4 Average Utilisation (%) 21.44 Module Average Module Utilisation (%) \SystemRoot\system32\hal.dll 8.04 \SystemRoot\System32\drivers\ACPI.sys 7.12 \SystemRoot\system32\ntoskrnl.exe 5.80 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name explorer.exe PID 2244 Average Utilisation (%) 3.73 Module Average Module Utilisation (%) \SystemRoot\system32\ntoskrnl.exe 1.45 \SystemRoot\System32\win32k.sys 0.96 \Device\HarddiskVolume4\Windows\System32\ntdll.dll 0.21 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name iexplore.exe PID 7208 Average Utilisation (%) 2.42 Module Average Module Utilisation (%) \Device\HarddiskVolume4\Windows\SysWOW64\mshtml.dll 0.57 \SystemRoot\system32\ntoskrnl.exe 0.30 \Device\HarddiskVolume4\Windows\SysWOW64\Macromed\Flash\Flash.ocx 0.27 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name csrss.exe PID 3768 Average Utilisation (%) 1.96 Module Average Module Utilisation (%) \SystemRoot\system32\ntoskrnl.exe 1.24 \SystemRoot\System32\win32k.sys 0.56 \Device\HarddiskVolume4\Windows\System32\winsrv.dll 0.03 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name dwm.exe PID 9024 Average Utilisation (%) 1.42 Module Average Module Utilisation (%) \Device\HarddiskVolume4\Windows\System32\dwmcore.dll 0.31 \SystemRoot\system32\ntoskrnl.exe 0.30 \SystemRoot\System32\win32k.sys 0.13 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name ISD_Tablet.exe PID 6824 Average Utilisation (%) 0.52 Module Average Module Utilisation (%) \Device\HarddiskVolume4\Program Files\Tablet\ISD\ISD_Tablet.exe 0.20 \SystemRoot\system32\ntoskrnl.exe 0.13 \Device\HarddiskVolume4\Windows\System32\ntdll.dll 0.05 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name taskhostex.exe PID 6332 Average Utilisation (%) 0.44 Module Average Module Utilisation (%) \SystemRoot\system32\ntoskrnl.exe 0.14 \SystemRoot\System32\drivers\WRkrn.sys 0.09 \Device\HarddiskVolume4\Windows\System32\esent.dll 0.08 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name WRSA.exe PID 904 Average Utilisation (%) 0.36 Module Average Module Utilisation (%) \SystemRoot\system32\ntoskrnl.exe 0.16 \Device\HarddiskVolume4\Program Files\Webroot\WRSA.exe 0.04 \Device\HarddiskVolume4\Windows\SysWOW64\ntdll.dll 0.03 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name OUTLOOK.EXE PID 3392 Average Utilisation (%) 0.29 Module Average Module Utilisation (%) \SystemRoot\system32\ntoskrnl.exe 0.09 \Device\HarddiskVolume4\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\MSO.DLL 0.03 \SystemRoot\System32\win32k.sys 0.03 CPU Utilisation:Individual process with significant processor utilisation. This process is responsible for a significant portion of the total processor utilisation recorded during the trace. Process Name lync.exe PID 3892 Average Utilisation (%) 0.24 Module Average Module Utilisation (%) \SystemRoot\system32\ntoskrnl.exe 0.07 \Device\HarddiskVolume4\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\MSO.DLL 0.04 \Device\HarddiskVolume4\Windows\SysWOW64\ntdll.dll 0.02 I want to add that before the last firmware update, this was never issue with the power settings i had in place. Thanks! MrTPN
I had almost the same. After the upgrade I charged the Surface, then pressed the button to turn off the screen. And that evening it was empty. I then started it and restarted it and charged it, now it seems ok.
Sorry to confuse everyone. After work I checked the surface and it was empty again, so there is deff something wrong. Sent from my Nokia Lumia 920 using Board Express
Same here - battery always almost flat after leaving it overnight. Putting it down to the notorious update as I haven't had the machine long enough to judge as to whether it was fine before. Roll on patch day...
This is due to the December firmware, trick is to use hibernate instead of sleep as a temporary fix. So change lid closed and power button from sleep to hibernate in the power options and put the SP2 in hibernate when not in use. If the SP2 does wake from sleep and the battery indicator is wrong, do a hardware reset by holding down the power button and volume + after shutdown.
Thanks, I may try that! Hopefully this issue didn't cause harm to our Surface Pro 2's by sticking them in our bag and the Microsoft firmware not allowing it to sleep. I can't imagine Apple sitting on a problem like this knowing it is causing their laptops to heat up in bags.
Yep, that did the trick! The system went into hibernate mode instead of staying on with the cover closed! Thanks!
I can't wait for the next update because this is a total fail... They need to release an update soon because some of us depend on the long battery life.... :-( I love the surface pro 2 regardless it's a fantastic device Update: I only had ONE day where the battery drained. Ever since, I've been using it with normal use and the SD card installed and everything is good. But still, I hope an update comes out to fix any issues for everyone!
Glad to hear it worked for you, spread the word that until the firmware update releases to use hibernate instead of sleep to get back the great battery performance.
I think the first step is MS is releasing the October Hardware update again as a short term fix, I received it today.
There's a firmware rollback method here: System Firmware Update - 12/10/13 fails to install - Microsoft Community I'm too scared to try it myself but for those braver than I, there it is. I will still wait for some new firmware, as my device only has some minor quirks, nothing too bad. EDIT: apparently this is not a genuine rollback method. Nothing to see here.
