Loose volume rocker on new Surface 2
Discussion in 'Microsoft Surface 2' started by rgbjr48, Oct 23, 2013.
  1. rgbjr48
    rgbjr48 New Member
    Oct 11, 2013
    4
    0
    0
    Hey all, just got my Surface 2 on Tuesday. Great tablet but one thing bothers me: the volume rocker is really loose. It travels quite a bit up and down. I just wanted to know if everyone else's does that too or should I return it?
  2. beman39
    beman39 New Member
    Jul 31, 2013
    433
    77
    0
    well does it rock loosely or slide loosely? if it does it ALOT, then I would def bring it back for a return as I don't think it's supposed to be loose well not on my Surface RT anyways...also is the volume still functioning properly?
  3. rgbjr48
    rgbjr48 New Member
    Oct 11, 2013
    4
    0
    0
    It definitely slides a lot, more so back and forth. It still functions but I worry over time it could malfunction. I think I will return it. Do I return it to bestbuy or will they tell me to contact Microsoft?
  4. Akinzekeel
    Akinzekeel New Member
    Oct 24, 2013
    3
    0
    0
    I have a similar Problem with a loose volume rocker. You can actually hear a clicking Sound when slightly shaking the device.
    I'll check back with the retailer today if I have time.
  5. beman39
    beman39 New Member
    Jul 31, 2013
    433
    77
    0
    bring it back to BB they should replace it for you if your not over the 30 day mark, if your over then they send it in to get repaired, probably to MS
  6. rgbjr48
    rgbjr48 New Member
    Oct 11, 2013
    4
    0
    0
    So I went into Best Buy and the customer service guy exchanged it with a brand new one no questions asked, that's great. However, when I got home and opened the new one it is still just as loose. Is the volume rocker supposed to be loose? It rattles when I shake the tablet. Can anyone with a Surface 2 chime in please? This is really frustrating.
  7. Akinzekeel
    Oct 24, 2013
    3
    0
    0
    Okay I just got back from the store. When I told about the problem they checked one of the displayed Surface 2 and supposedly it had the same problem.
    I still don't think this is right, but I am not sure what to do now.
    Edit: by the way I do own a Surface Pro 1 and the volume rocker is rock-solid on that one.
  8. The White Falcon
    The White Falcon New Member
    Oct 12, 2013
    126
    22
    0
    Other
    My volume rocker on my 2 is loose as well. Power button is better.
  9. oion
    oion Well-Known Member
    Feb 15, 2013
    1,362
    265
    83
    S2
    Can anyone post macro pictures to show this problem? I inspected my Surface 2 and the various buttons appear solid to my expectations, but I'm having a hard time imagining what the motion looks like for what you're reporting (compared to VaporMg flaking and whatnot). I wonder if it's a bad early batch.
  10. The White Falcon
    Oct 12, 2013
    126
    22
    0
    Other
    I can get pictures, but it rattles around if you shake the tablet, and you can move it up and down a bit. I have a build date of 9/2/2013 on mine, so it'd have to be one of the first ones.
  11. oion
    Feb 15, 2013
    1,362
    265
    83
    S2
    Ahh, okay. I just shook mine and it doesn't make a sound. How do you check build date?
  12. The White Falcon
    Oct 12, 2013
    126
    22
    0
    Other
    Mine had a sticker right on the box (sadly, right on the front of the box, by the big 2).
surface 2 loose volume button
surface 2 loose volume rocker
surface 2 volume button
surface 2 volume button loose
surface 2 volume rattle
surface 2 volume rocker
surface 2 volume rocker loose
surface pro 3 loose volume
surface volume button
volume button loose on surface 2
