Mail issue on our 1020s. Anyone help?
Discussion in 'Microsoft Smartphone General Discussion' started by kojack, Mar 9, 2016.
  1. kojack
    kojack New Member
    Oct 18, 2015
    27
    5
    3
    Surface 3 (Atom)
    In the past couple of weeks, My wife and I noticed that our mail is not being stored on our 1020s for longer than a day. It used to all be stored there. I never changed any settings. Any ideas how to fix this up?
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Are all the deices with that account set up IMAP? If not are they ALL set up to leave mail on the server.
  3. kojack
    kojack New Member
    Oct 18, 2015
    27
    5
    3
    Surface 3 (Atom)
    They are setup as POP accounts. But this only started happening recently....They used to leave a week or two on the phone...now its daily.
  4. GreyFox7
    Jul 27, 2014
    6,899
    1,385
    113
    Typically this is configured in the Account settings of the mail client.
  5. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    I;'m guessing a setting was changed on one of the mail clients. If you're using POP they (all but maybe one) should tell the mail to keep on the server for 14 days. That's the default for Outlook if you tell it to keep the mail on the server. Unfortunately there are a lot of variables. You need to double check the mail settings on all your systems. Making them all IMAP might be the best solution.
  6. kojack
    kojack New Member
    Oct 18, 2015
    27
    5
    3
    Surface 3 (Atom)
    THanks, I will check it out and see what I can come up with!
