HowTo Middle Click Autocad on surface 4
Discussion in 'Microsoft Surface Pro 4' started by achabmarco, Dec 28, 2015.
  1. achabmarco
    achabmarco New Member
    Dec 28, 2015
    13
    0
    Hi all,
    After weeks trying to find out how to middle click on a surface pro 4 using Autocad, I finally found a solution.
    Using AutoHotkey the following script seems to work fine. At least It's working fine in my case.
    $RButton::;HoldRButtonfor400ms to hold MButton down.
    KeyWait,RButton, T0.4;Ajust time as needed.
    if errorlevel
    { send {MButtonDown}
    KeyWait,RButton
    send {MButtonUp}
    else send,{RButton}
    return
    For some reason I cannot copy and paste with the right formatting, so, should you need the script, you can find it at:
    Right mouse click+hold=hold middle mouse button (REVIT PROBLEM WITH MAGIC MOUSE MIDDLE BUTTON SOLVED) - Ask for Help - AutoHotkey Community
    I am currently using with the touchpad on the latest keyboard.
    Hope this will help someone like me who likes to use autocad on the Surface, and would like to keep using the middleclick button.
    Just posting as I was unable to find a way to middleclick on a surface in this forum.
    EDIT:
    As I am a left handed it is more confortable if operated with the left click, so I modified the script just changing the word RButton to LButton.
    It works even better as I can hold the left click with the left hand while panning with the right hand.
    Seems confortable to me :)
    Cheers
    Marco
  2. rquellet
    rquellet Member
    Jul 6, 2014
    58
    16
    8
    Thanks! I'll try this with SolidWorks.
autocad middle click
autocad on surface pro 4 with pen
doing autocad on microsoft surface pro 4
middle click surface 4
middle mouse click on surface 4 keyboard
surface 4 middle click
surface pro 4 keyboard middle mouse click
surface pro 4 middle mouse button
surface pro 4 middle mouse click
surface pro middle click
