Mouse/Web Pages Help
Discussion in 'Microsoft Surface Pro 3' started by Akajak, Jul 21, 2015.
  1. Akajak
    Akajak New Member
    Jul 21, 2015
    2
    0
    Dear All,
    joined the forum as I cannot get a solution from Microsoft and wondered if anyone has had a similar experience with Surface Pro 3 and wedge mouse
    the problem I encounter is frustrating my use of surface pro 3; in a nutshell
    if I have a web page open and move the mouse pointer to a hyperlink, before I can click on the hyperlink the web page moves and I end up clicking on the equivalent of thin air or a different link; the web page scrolls up as I approach the hyperlink with the mouse pointer
    any help gratefully received; don't know if it's a contributory factor but the web pages are very small text difficult to read I always end up increasing their size by using finger gestures on the touch screen to enlargd
    TIA
    Andrew
  2. malberttoo
    malberttoo Super Moderator Staff Member
    Feb 26, 2013
    2,255
    428
    83
    Alaska
    Welcome Andrew!
    Which browser are you using? And is it just a single page that is the problem, or all pages? Also you specifically mentioned the Wedge mouse- are you saying this behavior doesn't happen if you use the touchpad on TypeCover, or a different mouse?
  3. Akajak
    Akajak New Member
    Jul 21, 2015
    2
    0
    thank you Michael
    it is IE 11 and Firefox 39; it happens on around 50% of pages and is very frustrating
    I haven't used the device without the wedge mouse as I prefer it to the touchpad but I will check;
    On the surface pro when I went to quick the reply button the page moved when the mouse pointer came near the post reply box
    thank you
    Andrew
