Need a little help
mike ammekilde
Hi everyone.
Just got my surface 3 I7 256gb.
Im having some problems when running Jdownloader. The screen ( program is too small ) and im having trouble making it really fit the screen properly.
Any help will be greatly appriciated.
First post btw.
bluegrass
I'm not familiar with Jdownloader but I have had situations where the text is too small to read on an application such as calibrating my Phantom quad. I created a shortcut on my desktop taskbar for the magnifier. It gets me through some unusually badly designed software.
I know this is probably not the solution you're hoping for but maybe it might help as a temporary work around. Now I'll go Google to see what Jdownloader is.
bluegrass
I was downloading and installing a copy of Jdownloader to try and see what you were talking about. During the download and installation process my Malwarebytes didn't like a lot of things it was doing so I bowed out. I don't want to wind up with adware on my computer. Hope you find a solution to your problem.
Antitoon
A handy shortcut for the magnifier which I discovered by chance:
Win + '+'.
This will launch the magnifier. After that, you can zoom in with
Win + '+'
and zoom out with
Win + '-'
M
mike ammekilde
Hi Again. Thanks for trying . Ive made it Work with your solution for the time being.
Its just a Little annoying to swith between magnifier and normal showing.
Hopefully they wil fix it sooner than later.
