Need powered USB 3.0 hub for continuous use
Discussion in 'Surface - Peripherals' started by stlbud, Oct 22, 2015.
  1. stlbud
    stlbud Member
    Nov 1, 2012
    102
    10
    18
    I need a USB 3.o hub that can power 2 or 3 hard drives and be used continuously. I've tried this Micro Center - Computers and Electronics and this Micro Center - Computers and Electronics . Both worked fine for 3 or 4 weeks then died. The Inland is recognized by the computer but nothing plugged into it is recognized. The Targus still works with a flash device but can't reliably power a hard drive. Because the power was intermittent it destroyed the contents on one of the hard drives.
    Any suggestions would be appreciated.
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    I'm surprised the Targus didn't work. I've been using Belkin and Trendnet powered 3.0 hubs without any issues.
  3. daniielrp
    daniielrp Active Member
    Oct 26, 2013
    693
    133
    43
    Preston, UK
    I used a belkin 7port powered hub a long time ago, it work well
  4. ScottyS
    ScottyS Active Member
    Apr 14, 2013
    726
    125
    43
    New York
    I first got a Satechi 10-Port USB 3.0 Hub (9 Port USB 3.0 + 1 iPad Charging Port) 5 Volt, 5 Amp which worked great for a couple of years and then the innards of the main USB in became dislodged from the circuit board. It was useless. I got a AmazonBasics 7 Port USB 3.0 Hub with 12V/3A power adapter for nearly 1/2 the price and it works great. It powers 2 HDs, a keyboard and mouse wireless USB receiver, charges my iPhone and more.
  5. jychow
    jychow New Member
    Oct 31, 2015
    10
    0
    Surface 3 (Atom)
    Maybe you can try j5create. Google it.
  6. bluegrass
    bluegrass Well-Known Member
    Nov 11, 2013
    1,308
    193
    63
    St. Louis, Mo
    Since the Microsoft's new docking station has a hunk of a power supply, with 4 USB ports on board, I wonder if it wouldn't server multiple purposes for you and be a reliable hub for you external disk drives?
    leeshor likes this.
