As the title says, there is only a balanced mode, shouldn't there be a power saver power plan?
K Korban New Member Sep 8, 2014 #1 As the title says, there is only a balanced mode, shouldn't there be a power saver power plan?
annabanana Active Member Sep 8, 2014 #2 I looked for it too, but I think it's been removed. The battery life on SP3 is much better than my SP1, so I'm happy anyway. Welcome to the forum.
malberttoo Well-Known Member Sep 8, 2014 #3 Korban said: As the title says, there is only a balanced mode, shouldn't there be a power saver power plan? Click to expand... Hi, welcome. The Surface Pro 3 is a Connected Standby device, and as such Microsoft has worked closely on it to tweak as much battery life as possible out of it. The limited options that you see in Power Options is by design.
