Original charger vs Ebay 3rd party chargers
Discussion in 'Microsoft Surface Pro 3' started by kiwigirl, Nov 4, 2014.
  1. kiwigirl
    kiwigirl Member
    Oct 24, 2014
    165
    17
    18
    I want a 2nd charger but refuse to pay $80 for the OEM one, that is just a joke. I refuse to get fleeced. I went on ebay and found a bunch of 3rd party ones, made and shipped from China for 1/3 the cost. Same specs in terms of wattage, amps, etc.
  2. GegeNY
    GegeNY Member
    Oct 22, 2014
    51
    2
    8
  3. bluegrass
    bluegrass Well-Known Member
    Nov 11, 2013
    1,308
    193
    63
    St. Louis, Mo
    I paid $200 for my second charger for my SP3, but it came with several USB ports, Ethernet, & a video port.
  4. hughlle
    Jul 7, 2014
    3,089
    465
    83
    Seems a vicious circle. Noone is buying one so noone is recommending one. I really want a DC charging cable for use with an external battery, but i can't find anyone who's bought one to offer feedback, just negative speculation which doesn't fill a cash strapped student with the confidence to buy one.
  5. bluegrass
    Nov 11, 2013
    1,308
    193
    63
    St. Louis, Mo
    You could buy that $27.66 eBay power pack the OP mentioned and wack the cable off to use with an external battery pack.
  6. Geneo
    Geneo Member
    Jun 22, 2014
    72
    16
    8
    Oklahoma, USA
    I was reading about the fraying/kinking of the cable at the magnetic plug end, and mine's 'getting there'. I can't do without my sp3(!), so I ordered a spare charger from Amazon for about $64. Still high, but cheaper than the OM version.
  7. joell85
    joell85 Member
    Jun 22, 2014
    39
    0
    6
    UT, USA
    Surface Book
    Just a tip, if there is anything wrong with your charger chat with MS support and they will send you a new one. They do not require you to send back the old one either so no time waste for you.
  8. annabanana
    annabanana Active Member
    Jul 12, 2014
    167
    48
    28
    at the beach
    Sounds risky to me. Sometimes you get what you pay for.
  9. riggi
    riggi Member
    Mar 29, 2013
    147
    25
    18
    I used a couple of third party chargers for my SP1 that came from China that I got off ebay.
    One was OK, but the other melted.
    I'm glad I happened to be looking at my SP1 as I was working at the desk because I saw it start to change shape and when I grabbed it, it was really hot.
    I dread to think what would have happened if I was not there and it kept melting and maybe damaged the SP1.
    The other third party charger is OK though... so, it's kind of a lucky dip.
    I haven't bought a 2nd charger for my SP3 yet, but if I do, I think I'll just pay the extra for a MS one rather than risk it.
    I think one problem is that these chargers are not like the standard barrel chargers of most laptops that just have a positive and negative wire going to the charger. Those things can be replaced by just about any other barrel plug that has the same size, polarity, wattage and amps. Also, just about anyone can easily reproduce them.
    The SP1 SP2 and SP3 chargers have more connectors and if the person making them cuts corners or just ignores some aspect, only concentrating on connecting the power wires, then there is more potential for something to either short or not function as it should.
    Like I said, my other after market charger for the SP1 has been fine, so you might be OK, but I'd just make sure you don't leave it charging unattended.
  10. lonaysta
    lonaysta Member
    May 10, 2014
    48
    6
    8
    I....personally won't risk the health of my battery to save 30-60 dollars...
  11. clrk9000
    clrk9000 Member
    Jul 3, 2014
    30
    3
    8
    I cut the wire connected of my SP3 Charger because the tip frayed and would not charge anymore.
    It is still delivering the 12V out so the problem lies somewhere in the frayed section near the magnetic connector.
    I bought from Amazon Marketplace (from China) this Outtop Power Bank Charge Magnetic Cable Line For Microsoft Surface Pro 3 for less than 10 bucks delivered. I hope I didnt get scammed, still waiting for delivery which will come a month from now as per Amazon notification.
    The wires coming out of the charger going to the tip is just positive and negative wires of the 12v supply.
  12. hughlle
    Jul 7, 2014
    3,089
    465
    83
    Question: Why didn't you just get Microsoft to send you a new one under warranty? Mine is beginning to show problems, in that if i wiggle the cable next to the magnetic connector it will stop charging and have to wiggle it to get it to start charging again. If it fails, i just send MS a message and they pop a new one in the post for me :)
12 v pins surface rt
default charger vs 3 party
ebay microsoft charger
microsoft charger ebay
microsoft charging ebay
microsoft surface charger differences
surface 2 charger wires
surface pro 2 charger positive negative pins
surface pro 3 128gb ebay
xbox oem play and charge kit vs 3rd party
