Pen not inking in one note when using skype
Discussion in 'Microsoft Surface Pro 3' started by Moonsurface, Sep 2, 2014.
  1. Moonsurface
    Moonsurface Super Moderator Staff Member
    Jul 13, 2014
    836
    202
    43
    UK
    Earlier I had an annoying problem. Due to lack of signal at my parents house on my mobile phone I decided to call a potential wedding photography client using skype. I decided I'd try to take notes from the conversation using one note snapped to the multi-app screen while also displaying a pdf I needed to refer to. I assumed this should work fine and I'd be able to ink on the onenote screen while looking at the pdf on the other screen and having skype working in the background. However that didn't happen. While the pen top button could easily enough open another note and I could snap between them in the multi-app screen I couldn't get the inking function to work at all.. most annoying.
    Anyone else found this??
    I just tried opening onenote and snapping to a second screen while running lots of other programs including LR in the other window and it's working fine now... just not while I was on my skype call!
  2. GreyFox7
    Jul 27, 2014
    6,793
    1,357
    113
    So was it just that one Skype call or anytime you bring up Skype?
  3. ctitanic
    ctitanic Well-Known Member
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Exactly, maybe it's just a one time issue.
  4. Moonsurface
    Jul 13, 2014
    836
    202
    43
    UK
    I have done tried it again and after a little hesitation it did indeed work. Just annoying it didn't when I really needed k it.
    Incidentally does anyone know if the headphone jack supports a mix input as I have headphones that have an inline mic which will have been better for the call quality when writing on screen.
skype inking
skype onenote
