Portable document scanner that works with 8.1 rt???
Discussion in 'Microsoft Surface 2' started by cldittus, Mar 25, 2015.
  1. cldittus
    cldittus New Member
    Sep 1, 2014
    22
    3
    3
    Just wondering if any of you out there have come across a stand alone portable document scanner that works with Surface 2 rt? I have looked at the compatibility center and I see barcode scanners but not document scanners. It would make my life a lot easier to if I could find one.
    Thanks in advance if you have any ideas.
    - Christi
  2. GreyFox7
    Jul 27, 2014
    6,792
    1,355
    113
  3. zhenya
    zhenya Active Member
    Feb 14, 2013
    441
    66
    28
    Do you carry a smartphone? There are apps that do a pretty remarkable job of scanning using the phone's camera.
  4. GreyFox7
    Jul 27, 2014
    6,792
    1,355
    113
    There's some Apps in the store iScan Air, iScan Air Go, ... that work with a portable scanner.
    HP and Brother also have apps but it's unclear what scanners they support.
    There are a couple portable scanners that scan to a microSD card.
  5. cldittus
    cldittus New Member
    Sep 1, 2014
    22
    3
    3
    Thank you all for the responses. I will check them out.
  6. evanpan
    evanpan New Member
    Sep 23, 2015
    2
    0
    SPro
    Yup indeed. Apps offered by smartphone's app store that do a pretty remarkable job of scanning using the phone's camera. You can check it later. I hope you success. Good luck.
    Best regards,
    Pan
portable document scanner forun
portable scanner compatible with surface rt
portable scanner that works with ms surface
scanners that work with a microsoft surface rt
what portable scanner works with the surface 2
