Post Your SP3 i7 Battery Life
Discussion in 'Microsoft Surface Pro 3' started by tallshorty, Aug 3, 2014.
What is your i7 battery life?
  1. 3-4hrs
    5 vote(s)
    18.5%
  2. 4-5hrs
    6 vote(s)
    22.2%
  3. 5-6hr
    11 vote(s)
    40.7%
  4. 7-8hrs
    5 vote(s)
    18.5%
  5. 6-7hrs
    0 vote(s)
    0.0%
  1. tallshorty
    tallshorty Member
    Jul 9, 2014
    33
    3
    8
    I'm debating if I should exchange my i5 for the i7 SP3. I already know that the i7 version does not throttle as low as the i5 version and can maintain a stable 2.29GHz and 75C temperature, whereas, my i5 throttles down to 1.5GHz and 65C temp.
    But what I don't know is the battery life. I can get around 6.5-7hrs on battery with the i5 version. If the i7 battery life is significantly less, than I probably won't upgrade.
    Can people post their battery life please? Thanks.
  2. Wiidesire
    Wiidesire Active Member
    Aug 3, 2014
    109
    32
    28
    Careful here. If you are talking about that one extended Youtube Video it was only a CPU Stress test. If you do a CPU+GPU stress test the i7 version also goes down to ~1,6 ghz.
    be77solo likes this.
  3. double07
    double07 Member
    Jun 21, 2014
    157
    17
    18
    My initial non-scientific battery tracking yesterday. I am getting 7 to 8hrs on my usage. I got 100% at 2:30pm, non stop normal usage, web, email, MS word, Youtube, install app, etc... No games. I don't do game. 58% by 6:30pm. Continue to use with what I would do normally, 30% by 8:30pm. Got down to 10% the rest of the night. I charged back up to 64% by mid-night. Unplugged power. In the morning 8am, it dropped to 61%.
    I think, my battery life is pretty good on my SF3 i7.256. At least, base on my normal usage.
  4. tallshorty
    tallshorty Member
    Jul 9, 2014
    33
    3
    8
    Check your battery report. It will show your battery consumption more accurately. On normal use (internet browsing, word, some video streaming) my average is about 15% per hour.
    Here is the script: RUN and enter --> powercfg /batteryreport /output %USERPROFILE%\Desktop\battery_report.html
    A HTML report will be generated on your desktop
    Also can someone report their battery capacity? Is it the same as the i5? My i5 is 42,484 mWh
  5. be77solo
    be77solo Active Member
    Nov 12, 2013
    239
    33
    28
    I'm not sure why, but I can't get battery life out of either the i5 or i7 SP3 comparable to my SP2.
    I get 4ish hours out of either SP3's.... I don't notice much difference between the two.
    And yes, the i7 has the same size battery as the i5 and the SP2.
  6. J997tt
    J997tt New Member
    Aug 3, 2014
    2
    0
    First post. Very useful forum. Unscientific but I am seeing 6.5 hours web browsing, using Office suite, other non-heavy work load. Surface Pro 3, i7, 512... I traded a i5, 256 for this and feel it's generally faster - again non scientific seat of the pants. I do like the SP3 a lot.
  7. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
  8. J997tt
    J997tt New Member
    Aug 3, 2014
    2
    0
    Thanks admin. Appreciate it.
  9. tallshorty
    tallshorty Member
    Jul 9, 2014
    33
    3
    8
    I just realized I skipped 6-7hrs in the poll.
    Anyway to add that in?
  10. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Added but could not do it in order.
    UltraDroid likes this.
  11. Deryl McCarty
    Deryl McCarty Member
    Dec 3, 2012
    99
    26
    18
    Puyallup, WA
    Surface Book
    running powercfg -batteryreport is still guessing about 5:04...and things are settling down a bit so heat is hanging around 66-75 (processor 1 is 4-5 degrees cooler. ) so I suspect battery life will extend a bit over the next days but I think that 6 for me will be about what to expect. I will live with that since my sp2 was only 4 and my more recent laptops are 2.5-3. But recall I am no gamer nor do I know which end of the camera to use, so both my battery and CPU heat risks are lower than some of you.
  12. macmee
    macmee Active Member
    Oct 15, 2013
    717
    70
    28
    Damn I wish the batter was better :(
battery life surface pro 3 i7
sp3 i7 battery
surface pro 3 battery life i5 vs i7
surface pro 3 battery life i7
surface pro 3 i7 battery drain
surface pro 3 i7 battery life
surface pro 4 i5 vs i7 battery life
surface pro 4 i7 battery
surface pro 4 i7 battery life
surface pro i7 battery life
