Power Adapter Weirdness
Discussion in 'Microsoft Surface Pro 2' started by MoggSquad, Nov 2, 2013.
  1. MoggSquad
    MoggSquad Member
    Oct 22, 2013
    30
    0
    6
    I notice when I connect the SP2 to the power adapter my screen will flash dim and bright over and over for approx.. 10-12 seconds until it finally starts charging properly. Basically it's going into charging to non charging for each bright/dim cycle. My Surface RT never did this. Wondering if other SP2 owners are having this or if my charger is defective.
  2. Rvacha
    Rvacha Member
    Mar 9, 2013
    181
    14
    18
    I haven't seen this myself
  3. Name Taken
    Name Taken Active Member
    Aug 11, 2013
    183
    26
    28
    Is your problem similar to the screen flickering people were having here? It turned out to be Intel Dynamic Power Saving feature. You can disable it from the Intel Graphics Control Panel after updating your driver.
  4. F1ADAM
    F1ADAM New Member
    Nov 4, 2013
    4
    Hi
    I found this happened when the connector wasn't seated properly.
    Once all the contacts were connected the device power management stopped swapping between plans.
microsoft surface goes bright to dim when charging
surface 2 power adapter problem
