Power Management Problems & ASPM
Discussion in 'Microsoft Surface Pro' started by z3razerviper, May 31, 2014.
  1. z3razerviper
    z3razerviper New Member
    Oct 19, 2013
    11
    0
    Ok my surface has horrible battery life even a complete reinstall of 8.1 with update 1 from msdn did not improve it much so after running powercfg /energy i receive the following 2 errors
    Note this is the origional surface pro with all the latest patches & drivers from windows update. Does anyone have any idea what causes the ASPM one? I mean you would think MS could get power management right on a machine they designed...
    The one that concerns me the most is
    Platform Power Management Capabilities:pCI Express Active-State Power Management (ASPM) Disabled
    PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
    and this one seems to be related to the wifi card
    USB Suspend:USB Device not Entering Selective Suspend
    This device did not enter the USB Selective Suspend state. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping.
    Device Name USB Composite Device
    Host Controller ID PCI\VEN_8086&DEV_1E31
    Host Controller Location PCI bus 0, device 20, function 0
    Device ID USB\VID_1286&PID_2044
    Port Path 3
  2. danihun
    danihun New Member
    Jul 18, 2013
    9
    3
    Amsterdam
    Did you try to reinstall the drivers?
  3. guymalloc
    guymalloc Member
    Apr 1, 2014
    130
    23
    18
    Nebraska
    I just ran powercfg /energy on my 'new' surface pro 1, just bought a month ago. I had 25 errors, including
    I think all of mine except that one, are because I pretty much turned off any performance reducing settings in the power configurations. No hibernation, or sleep for my surface. When I'm using it, I want no interruptions, screen timeouts, drive turnoffs, usb shutoffs, nothing....
    When I'm on battery, I still get about 4 hours in tablet mode, a little less with my type cover 2 and bluetooth mouse. And when I'm done, I turn it OFF. I guess I'm old school, lost too many hours of work not saving documents, or other work, as I went, and then losing something because my PC decided to sleep or hibernate 'cause I went to the can, or out for a smoke. Most 'good' software has an autosave feature, I always use it if available. And even Microsoft tells people to occasionally turn off their PC. This allows for updates to finish installing, and clears memory allocation errors, common to all software, no matter how good it is.
  4. z3razerviper
    Oct 19, 2013
    11
    0
    Yes all the drivers have been reinstalled.
aspm disabled due to hardware incompatibility
aspm has been diabled due to known incompatibility
aspm has been disabled due to a known incompatibility with hardware
aspm incompatibility
pci express active power management
pcie aspm issue
surface pro aspm disabled
venue pro aspm disabled
wifi card aspm
