Power Options
awesome
Hi everyone,
I have a question about the power options. I always have some background downloads (torrents, etc). Current power options turns the display off after 2 minutes. Surface also goes to sleep and all the downloads stop at the same time. So, I need help to make the configuration that display will turn off, but downloads won't stop.
malberttoo
Hi everyone,
Basically the only way you can do this is to use an app downloaded from the Microsoft store. Otherwise, desktop apps will always have this issue.
A
awesome
Thanks for the info . What is the name of the app? Do you think this will be solved when windows 10 is released?
