Problems with Bluetooth mouse
Discussion in 'Microsoft Surface Pro 3' started by a9l6i, Nov 15, 2014.
  1. a9l6i
    a9l6i New Member
    Nov 15, 2014
    10
    0
    Hi there,
    I have a Surface Pro 3 (128Gb) with windows 8.1. I bought a bluetooth mouse and tried to connect it with my Surface. The connection works well, my Surface find the mouse and it tells me that it is connected with it. However mostly the mouse doesn't work although it says that it is connected. And when it works then it is very slow and not really useful. I tried everything and searched a lot in the Internet and found out that many people have these problems but without a solution.
    I hope you know a solution
    Thanks in advance
    a9l6i
  2. jnjroach
    Nov 9, 2012
    7,734
    1,832
    113
    Seattle, WA USA
    Surface Book
    If you can switch your WiFi to 5GHz it will improve the performance.
  3. cam30era
    cam30era New Member
    Nov 6, 2014
    12
    0
    I'm not sure that I understand the relationship between what frequency my WiFi network is connected on and Bluetooth mouse connectivity issues?
  4. jnjroach
    Nov 9, 2012
    7,734
    1,832
    113
    Seattle, WA USA
    Surface Book
    Is a phenomenon known as Contention, on the Marvell Wireless Card; WiFi, Bluetooth, FM Radio and NFC (the last two are not activated on the Surface line) are all on the same Die....WiFi can operate on 2.4GHz (typically defaults to this on the Surface) Bluetooth always uses 2.4GHz and what you are seeing is Contention between the 2 radios operating on the same frequency, so moving to 5GHz on WiFi removes the Contention.
    ScottyS and cam30era like this.
  5. a9l6i
    a9l6i New Member
    Nov 15, 2014
    10
    0
    Hay
    thank you for your fast answers but how do I change the settings of my WiFi?
  6. cam30era
    cam30era New Member
    Nov 6, 2014
    12
    0
    Thanks, a lot. I learned something today.
  7. jnjroach
    Nov 9, 2012
    7,734
    1,832
    113
    Seattle, WA USA
    Surface Book
    You first need a router that is Dual Band...then setup the Router with Seprate SSIDs typically the 5GHz is desiginated by SSID_Name_5GHz. Another fix is getting Bluetooth Mouse that is v. 4.0 or v. 4.0LE and you will see better performance...
  8. a9l6i
    a9l6i New Member
    Nov 15, 2014
    10
    0
    Do you think the Microsoft Sculpt mouse would work well with the surface pro 3? Particullary solve my problem?
  9. cam30era
    cam30era New Member
    Nov 6, 2014
    12
    0
    I am experiencing a different problem. Occasionally when I boot my SP3, it will not detect my Logitech Bluetooth keyboard and mouse. I have to tell the SP3 to forget the devices, then pair again. I searched and have not been able to find a solution. Thanks in advance for any input.
  10. jnjroach
    Nov 9, 2012
    7,734
    1,832
    113
    Seattle, WA USA
    Surface Book
    I use the Sculpt Mouse without issue....
    a9l6i likes this.
  11. riggi
    riggi Member
    Mar 29, 2013
    147
    25
    18
    This happens to me too. Only occasionally, maybe once every 1 or 2 weeks. (I shutdown every night and also between work and home as the SP3 has a habit of waking in the bag).
    I use a Logitech K810 and Razor Orochi mouse.
    Instead of re-pairing both devices, I find just disabling and enabling the BT adaptor in device manager fixes it.
    A reboot will also fix it.
    cam30era likes this.
  12. Nys299
    Nys299 Member
    Sep 27, 2014
    77
    11
    8
    I use the Sculpt Touch Mouse and the Sculpt Comfort Mouse and both have no issues. Remember to go to the device manager and Bluetooth and uncheck the Power Management "Allow the computer to turn off this device to save power". I find that the mouse goes to sleep after sometime and there is no way to revive the mouse short of a reboot or repairing. Once I turn off the above, no issues with my mouse.
bluetooth mouse does not connect at startup
bluetooth mouse fro surface pro3 cennection ifx
microsoft surface support mouse mouse problem
mouse connection to surface pro
my surface pro 3 does not detect my bluetooth mouse
problems with surface mouse
surface pro 3 windows 10 mouse issue
surface pro 4 bluetooth mouse issue
unpair arc point mouse from surface pro 3
windows will not discover my survace mouse
