Is it possible to use remote desktop through a Bluetooth connection
D donebrasko New Member Aug 21, 2014 #1 Is it possible to use remote desktop through a Bluetooth connection
M mohcho Active Member Aug 21, 2014 #2 I assume you're referring to Windows Remote Desktop? If so, then no I do not believe so. Only works via network connection - wifi or wired.
OP D donebrasko New Member Aug 21, 2014 #3 Are there any remote apps that let you connect through Bluetooth?
ctitanic Well-Known Member Aug 21, 2014 #4 donebrasko said: Are there any remote apps that let you connect through Bluetooth? Click to expand... Never has seen one. It's technical no possible.
