Reset to Factory Question: Surface RT
Discussion in 'Microsoft Surface General Discussion' started by IridiumCore, Sep 21, 2013.
  1. IridiumCore
    IridiumCore New Member
    Sep 20, 2013
    15
    0
    Hello,
    I have a question about the RT. I removed the recovery partition from my Surface and misplaced the USB drive. I'm thinking I can rest my RT to the factory state thus recovering my recovery partition.
    This is a theory I have. Do any of you think that this will work to recover my recovery partition?
  2. machistmo
    machistmo Active Member
    Nov 17, 2012
    791
    53
    28
    Raleigh NC
    Other
    the recovery partition is where the 'restore' or 'reset' files were stored, if you removed that you cannot reset. You might be able to find the recovery files available for download and place them on a USB and then reset the device.
  3. Omni
    Omni Active Member
    Oct 27, 2012
    387
    35
    28
    UK
    Ive seen a few people online that have uploaded the recovery partition. Do some googling and youll find it. Or just update to 8.1 RT.... :wink:
  4. IridiumCore
    Sep 20, 2013
    15
    0
    thanks gents. I don't know how I undid the changes made to my USB but the information is back on there
  5. j100deal
    j100deal New Member
    Aug 6, 2013
    2
    0
    0
    I have upgraded to Windows 8.1, however I have decided to get a Surface 2 and give my original surface to my step son for his birthday, but when I try and restore to factory settings it says that I have missing files.......
    Does anyone have any ideas?
  6. williamd
    williamd New Member
    Nov 21, 2012
    7
    0
    0
    Hello all
    I have done alot of testing with win 8 and win 8.1 on the rt. And this is how it works. If you delete the recovery on the rt to gain space. And you install the 8.1 the recovery partition will not be there. You have to install win 8 off your thumb drive to factory specs and your recovery drive will be there and then when you install the win 8.1 you will have the recovery drive there. It works the same on pc's ,surface pro and the rt. So in short you have to have the recovery on the machine or it won't be there when you up grade or clean install 8.1. hope it helps.
    Also if you don't have the recovery partition when you upgrade to win 8.1, you won't be able to make a recovery image on a USB because the image isn't there . If you go to recovery its grayed out.
cannot restore surface rt from usb drive
factory reset surface rt
how to factory reset surface rt
reset surface rt
reset surface rt from usb
surface reset
surface rt 8.1 recovery partition missing
surface rt factory reset missing files
surface rt missing files
