SanDisk 128 GB Format for Speed?
Discussion in 'Microsoft Surface Pro 2' started by JeffBusse, Mar 26, 2014.
  1. JeffBusse
    JeffBusse New Member
    Mar 26, 2014
    4
    0
    I purchased on of the SanDisk 128gb SDXC which claim 30 mb write speed.
    I'm only getting around 15 in the Surface Pro 2. Is there a best way to format this to get better speeds at writing?
    It's great for read and that's whats important as I put all my music and videos on it but it just takes a bit to transfer over.
    Surface Pro 2 i5 8gb 256gb
    Type Cover 2
    incipio feather case
    SanDisk Ultra 128GB
  2. Jeffrey
    Jeffrey Administrator Staff Member
    Jun 18, 2012
    226
    89
    28
    Thailand
    Welcome to the Forum. I believe the speed is limited to the speed the SD slot supports. The SP2 may not support 30mb.
  3. GoodBytes
    GoodBytes Well-Known Member
    Jan 29, 2014
    1,071
    170
    63
    exFAT will give you the best performance as you don't carry all the extra stuff from NTFS.
    Please note that exFAT format may not work on other devices. Windows Vista and up, no problem.
    You must remember that write speed mentioned on the package is the absolute best the chip can get to under absolute ideal conditions. Not an average and real word results.
  4. andrew.zaitsev
    andrew.zaitsev New Member
    Mar 25, 2013
    15
    3
    3
    I'm format only NTFS
  5. benjitek
    benjitek Active Member
    Jan 7, 2014
    622
    70
    28
    SPro2
  6. be77solo
    be77solo Active Member
    Nov 12, 2013
    239
    33
    28
    SanDisk Ultra's are slow, you're getting about all it can do. I've got a 64gb and it writes the same as what you are seeing regardless of formatting I've tried.
    By comparison, the Extreme Pro level cards are faster and get 50-70 writing like Benjitek mentioned... but they aren't available in 128gb yet and are usually about twice as expensive.
    I have also had great luck with the Samsung Extreme cards for others curious, not quite as fast as the fastest SanDisk Extreme Pro but almost and totally stable and cheaper.
    1 person likes this.
  7. Rvacha
    Rvacha Member
    Mar 9, 2013
    181
    14
    18
    I can't speak for speed since I stopped using SD due to the high CPU issue, but I can say this - if your machine exhibits freezes/crashes I wouldn't touch anything other than NTFS, regardless of speed impact (if any). NTFS is the only format I have used/would ever use on an SP2
  8. JeffBusse
    Mar 26, 2014
    4
    0
    Thanks for the info here, I'll check into the high CPU but I don't think its effecting me. Battery life is good, fans rarely run except for after effects or premiere rendering.
    Great forum here, and thanks again, I guess I'm waiting for an extreme version, but till then this seems to work. I'm using exfat, but may run tests then switch to ntfs and see if there's any difference.
  9. benjitek
    Jan 7, 2014
    622
    70
    28
    SPro2
    Maybe the freezes/crashes were a problem with the older 4200 CPU SP2's -- I've had my 4300 520GB SP2 for a couple months now and I've not experienced a single lockup -- had the exFat-formatted card inserted since day 1.
  10. be77solo
    Nov 12, 2013
    239
    33
    28
    Nah, exFAT works just fine on all the Surfaces, from my old Pro 1 to my original Pro 2 with 4200 and a replacement with 4300.... all worked the same, 100% reliable.
    Only issue with SD cards and the Surface Pro 2 (both 4200 & 4300 cpu's) is an annoying random 20-30% CPU usage problem with System/System Interrupts... almost impossible to notice unless you keep Task Manager open all the time, which I do until this problem is fixed.
  11. javispedro
    javispedro Member
    Mar 16, 2014
    133
    4
    18
    Barcelona
    It also makes the SFPro hot to the touch, even if you've just been starting at the start screen.
  12. MCube74
    MCube74 Member
    May 18, 2014
    52
    3
    8
    So exFat is better for Surface Pro 2 then NTFS and Fat32?
    I have a Samsung 64GB MicroSDXC UHS-1 card rated at 70mb/s read and 20mb/s write.
    Just wondering which file system do I format my MicroSDXC card?
128 gb sd card format
format 128 gb sd card
sandisk 128 gb microsd write speed
sandisk 128 in surface
sandisk 128 native format
sandisk 128gb microsd surface pro format
sandisk ultra 128gb format
surface pro 2 4200 slow down due to sd card one drive
surface pro 3 sandisk 128
will 128 mb micro sdxc work on surface pro 3
