Scaling Issue In/Out of Dock
Discussion in 'Microsoft Surface Pro 4' started by unni, Jan 31, 2016.
  1. unni
    unni New Member
    Jan 31, 2016
    18
    2
    My previous post about this was removed, not sure if it was because I posted in a thread that was marked as solved or if it looked similar to my another post. So posting here again. I apologize if I broke any forum rules.
    My setup:
    • Surface 4 Pro
    • Surface 4 dock (brick style)
    • Belkin Mini Displayport to HDMI adapter
    • Asus VE247 Monitor - 1920 x 1080, 23.6"
    • When docked, I use only my monitor.
    • Tablet is at 200% scaling, monitor is at 100% scaling.
    Problem:
    When I dock/undock the tablet, the fonts look blurred. For example, if I have browser open when it was docked and using the monitor, the fonts will be blurry when I undock it and vice versa. I have observed this problem with Outlook/Word 2016, Visual Studio 2015, Opera, Firefox etc. Edge and store apps doesn't seem to have the problem. The only way I know so far to resolve this is to reboot the tablet. I have uploaded a screenshot here to give a better idea. The first screenshot was taken from tablet, the second from monitor.
    Anybody else solved this problem?
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    The problem was that you posted what was basically the same post in an active thread then started another thread. This is very close to the other thread still open. It's called cross posting and isn't allowed.
  3. unni
    unni New Member
    Jan 31, 2016
    18
    2
    Sorry. I thought this post was about using Surface along with a monitor as a dual display. My issue (posted above) happens when I am using just the monitor. The other post was also dock related, but the problem was different. This post is about the scaling issue, the other was about monitor alternating between on/off rapidly.
  4. Glenn.Q
    Glenn.Q New Member
    Jan 22, 2016
    13
    3
    I have a similar problem while using the monitor without a dock but directly connected to the mini display port.
    Scaling wont change (on the Surface its 200%, on monitor-only its supposed to be 125%).
    Connecting the monitor sometimes leads to blurry fonts and especially to wrong scaling (200% on the monitor).
  5. JordanAT
    JordanAT Member
    Nov 1, 2015
    38
    8
    8
    MS does not support connected and disconnecting the dock to monitors with a scale which differs. They recommend logging out and back in when you dock, or powering down, docking, and powering back up.
    No, this is not ideal, but it is currently the only way Windows works. AFAICT the problem is actually in the 3rd party software ability to scale properly if the monitor setup changes after the program is active (i.e. I think they only check at startup). Sorry, but there is neither a workaround nor a fix, and, if I remember the recent MS paper on this, it may not be something that even can be fixed for all applications. They are working on better scaling performance, but this one is likely not to be changed/fixed.
  6. dstrauss
    dstrauss Active Member
    Sep 26, 2012
    164
    106
    43
    Midland, TX
    Strange. I use my Surface Pro 4 (at 250% scaling - old eyes, sorry about that) with the new dock and two dispalyport Acer K272HUL monitors (2560x1440 set at 150% scaling). Text is crisp and sharp. Videos no problem. No gaming - use almost exclusively Office 2016, Adobe Acrobat XI, Drawboard, Edge, and Chrome.
    If I change scaling while running, it will ask me to log out and back in, but now that I have settled on the 150/250 solution it has been pretty stable.
  7. yazruel
    yazruel New Member
    Jun 26, 2016
    0
    Hi dstrouss,
    this gave me an idea for a workaround for the problem - set a different scaling value (not 100%) for my external monitor, and see of the scaling problem persists.
    Actually, it seems to have solved the problem... with 200% scaling on my SP4 display and 125% scaling on the external monitor problems seems to have disappear..
    now if only I could scale it to 105% instead of 125% it would have been great solution.
ie not scaling when docking surface pro
ie scaling when undocking surfface pro 4
ie11 menu scaling problem in windows 10 on surface pro dock
ms surface pro 4 scaling issues with dock
surface dock resize
surface log off scaling dock known issues
surface pro 4 ie 11 scaling issue
surface pro 4 scaling issue on ie toolbar
surface pro 4 undock scaling issue
