SkyDrive is Killing My Hard Drive
Discussion in 'Microsoft Surface 2' started by floorouncher, Dec 2, 2013.
  1. floorouncher
    floorouncher New Member
    Nov 28, 2013
    7
    0
    0
    So I noticed this morning that SkyDrive is filling up the hard drive on my Surface 2 by attempting to sync all of my files from SkyDrive to the local disk. The problem is that there is not enough space to put all of my files on the drive and it prevents me from opening other files from SkyDrive, giving me an error that says I don't have enough space. I know with the older Desktop app you used to be able to select which folders you wanted to sync... is this not an option with 8.1? I don't want SkyDrive to put anything on my tablet; I just want to be able to access my files via SkyDrive on my Surface and still have the files sync between my Desktop and Laptop.
  2. oion
    oion Well-Known Member
    Feb 15, 2013
    1,362
    265
    83
    S2
  3. Matthew
    Matthew New Member
    Dec 2, 2013
    20
    0
    0
    How do you check that?
  4. hotphil
    hotphil Member
    Apr 7, 2013
    118
    8
    18
    The toggle switch for "all files offline" is broken in Windows 8.1. A reboot seems to clear whatever state you set it at and it reverts to the other.
    To check it, from within the SkyDrive Modern UI app, check the settings.
  5. floorouncher
    Nov 28, 2013
    7
    0
    0
    I was able to fix the issue by managing the individual folders from within Windows Explorer in desktop mode. Kind of a pain, but it worked. Thanks.
does skydrive files take up space on surface rt harddrive
my one drive is using all my memory space on my surface if i switch one drive off my surface will all my files still be
not enough drive space on surface skydrive
not enough drive space skydrive
onedrive hard drive space rt
skydrive desktop taking up all my hard drive
skydrive filling up hard drive
skydrive folder on my hard drive
skydrive online only taking up space
surface pro skydrive filling harddrive
