Skype Volume Too Low
Discussion in 'Microsoft Surface Pro 3' started by InspectHerGadget, Nov 8, 2014.
  1. InspectHerGadget
    InspectHerGadget Active Member
    Sep 1, 2014
    429
    58
    28
    Thank you for your efforts.
    I'm going into a shop tomorrow just to compare sound volume side by side with another Surface.
  2. InspectHerGadget
    Sep 1, 2014
    429
    58
    28
    I compared the volume side by side although not on skype with a Surface Pro 3 in the shop and the volume levels were the same.
    I got the guy to listen to the Skype Test call and he agreed it was too soft, even at 100% volume.
    I suggested maybe testing Skype sometime if he could.
    It looks to me like it is the way the speaker/sound system is designed. It seems inadequate.
    It might be back to Facetime when I need to communicate or my desktop (which works fine on Skype).
  3. TravFlex
    TravFlex New Member
    Nov 10, 2014
    13
    0
    Did this get resolved?
    I had the same issue when mine was new out box. I also don't fully recall how I fixed it. I think Manage Audio Devices > Double click speaker > Levels
    Somehow I feel this was not tied/linked to the master volume originally but it seems to be now. Maybe install Skype Desktop App and see if it does the same? I think this is a software issue and nothing wrong with the hardware. Are all the updates installed?
  4. InspectHerGadget
    Sep 1, 2014
    429
    58
    28
    Yes, tried the desktop Skype with same results.
    Updates are installed.
    If there is a software fix, it would be great as, it isn't much good for Skype at the moment.
    It seems some people found some software fix for it but when directed to Sound, Enhancements etc., nothing was found.
  5. Dunwa
    Dunwa New Member
    Nov 11, 2014
    10
    0
    I've got the same problem with my SP3. Skype just about works in a quiet room at 100%. Strangely the default windows sounds are fine in the low 30%.
  6. InspectHerGadget
    Sep 1, 2014
    429
    58
    28
    I'm pleased that the hair growing on my palms isn't a sign of insanity then...:)
  7. jonco
    jonco New Member
    Jun 9, 2018
    2
    0
    Surface Book
    In case anyone else visits this site, the problem is easy to fix on my wife's Acer notebook. In control panel, I opened RealTech Audio Manager, Microphone and adjusted Microphone Boost which was set to zero. We increased it to 24 which then worked fine, but have now increased it to 36. However on my Surface Book, I don't have an audio manager as such, so in our case it was the other computer that had the problem, not the Surface.
3 volume skype too low
android skype for business sound is very low
microsoft surface skype app louder
skype volume
skype volume low
skype volume too low
surface 2 volume skype low
surface pro 3 low volume
surface pro volume low
surface volume too low
