Slow wifi when using bluetooth mouse
Discussion in 'Microsoft Surface Pro 2' started by Ruriko, Apr 7, 2015.
  1. Ruriko
    Ruriko New Member
    Nov 12, 2013
    23
    0
    When ever I use my bluetooth mouse my wifi starts lagging bad. Is there any fix for this? I already updated to latest firmware and still lags
  2. jnjroach
    Nov 9, 2012
    7,735
    1,833
    113
    Seattle, WA USA
    Surface Book
    Use 5GHz WiFi Bands and the lag will go away....Bluetooth and WiFi using 2.4GHz causes the "Lag" you are experiencing, also known as Contention.
  3. Ruriko
    Ruriko New Member
    Nov 12, 2013
    23
    0
    my router doesn't support 5ghz :(
    so is using wired mouse my only choice now? I just wish the usb port was on the right cause it feels weird having it on the left side
  4. jnjroach
    Nov 9, 2012
    7,735
    1,833
    113
    Seattle, WA USA
    Surface Book
    Sounds like it time for a Router Upgrade :) I bought a Travel Router for work (we have Ethernet at our desks so I plug that into my travel router) so I can 5GHz AC for my SP3.
  5. benjitek
    benjitek Active Member
    Jan 7, 2014
    622
    70
    28
    SPro2
    Unfortunately this is a known hardware issue with the WiFi/Bluetooth Marvell Avastar 350N combo chip used in the SP2. When both Bluetooth and WiFi are being used, WiFi speeds are reduced by approximately half.
    It was supposedly addressed in numerous firmware updates when the SP2 was the current model, however, nothing ever changed -- Microsoft doesn't bother any longer.
  6. GreyFox7
    Jul 27, 2014
    6,777
    1,351
    113
    It's likely a limitation of the Marvell chip but others may not be any better.
  7. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    I see that same complaint on many different tablets. I'm not certain it's only the Marvell chip.
  8. benjitek
    Jan 7, 2014
    622
    70
    28
    SPro2
    It is apparently fixed in new versions of the Avastar chipset, so any device that has the 350N has the same issue. Would be less of an issue if there were a straightforward way to force a 5ghz connection in the settings of my SP2.
marvell avastar wireless-ac surface pro 3
microsoft surface plugging in mouse causes wifi speed to drop
