(Solution) stretched screen games and high resolution desktop
Discussion in 'Microsoft Surface Pro 2' started by Pochowandpoch, Mar 30, 2014.
  1. Pochowandpoch
    Pochowandpoch Member
    Nov 11, 2013
    55
    48
    18
    Hi guys,we've all had this problem in some games when we choose a lower resolution to 1080p,to solve this was easier to change the desktop resolution to 1600 X 900,therefore it is not very nice.
    The problem is that the resolution 1920 X 1080 keeps your screen scale,need to leave it scaled to full screen.
    Started,downloaded drivers from Intel Iris here
    We have uninstalled the and install with the option of using disk (igdlh64.inf),after install have to reinstall from the (setup),restart..
    Open folder and let C:
    [​IMG]
    [​IMG]
    -> Windows/system32/
    [​IMG]
    [​IMG]
    Run CustomModeApp2_0
    [​IMG]
    [​IMG]
    Now create a resolution 1920 x 1078 60Hz and add.
    [​IMG]
    Restart the surface (important)
    Now we right click on desktop -> change resolution
    Advanced settings
    [​IMG]
    View all modes
    [​IMG]
    We choose the resolution that we have created (1920 x 1078 - 60Hz)
    [​IMG]
    Accepting.
    [​IMG]
    All set, now we have a similar resolution to 1920 x 1080 (will not notice the difference).:wink:
    A look at the control panel
    [​IMG]
    Now you will not have problems in games to stretch the screen and maintain a nearly identical resolution to 1080p.
    [​IMG]
    I recommend.
    PD/Sorry for my english.:cry:
    Greetings.:wink:
    1 person likes this.
  2. GoodBytes
    GoodBytes Well-Known Member
    Jan 29, 2014
    1,071
    170
    63
    Will add to my Surface Tweak Tool. Thanks.
  3. Pochowandpoch
    Nov 11, 2013
    55
    48
    18
    Excelent :)
  4. kozak79
    kozak79 Active Member
    Nov 15, 2013
    296
    61
    28
    Is there anyway (registry hack?) to enable this option for 1920x1080 resolution? I use 3D and Design software and need all the pixels I can get. Plus reducing the vertical resolution by 10 pixels would make it a bit blurry, wouldn't it?
  5. GoodBytes
    Jan 29, 2014
    1,071
    170
    63
    I have currently not found it when I looked through at the driver configurations in the registry.
  6. Pochowandpoch
    Nov 11, 2013
    55
    48
    18
    Post edited, 1920 x 1078 - 60Hz.
    Greetings.
  7. MikemanSP4
    MikemanSP4 Super Moderator Staff Member
    Dec 15, 2015
    259
    49
    28
    Nuremberg, Germany
    Surface Book
  8. GoodBytes
    Jan 29, 2014
    1,071
    170
    63
    If you are under Windows 10, Windows 10 will re-install the firmware and you'll lose the drivers that you just installed.
  9. MikemanSP4
    Dec 15, 2015
    259
    49
    28
    Nuremberg, Germany
    Surface Book
    I have my Windows set not to update drivers unless I tell it to. But your right - if thats not set - it will trudge along with whatever in the heck it wants to do...
blurry games stretch resolution
medieval ii stretched screen
stretch surface rt screen lower resolution help tutorial
stretch the screen with low res on surface pro 4
surface pro 3 stretch screen
surface pro screen resolution no stretch
surface stretch screen resolution
windows 10 resolution 1920x1080 stretch
